Bender Posted January 30, 2016 Share Posted January 30, 2016 Are brake discs and rockercover gaskets are same for TT and NA ? I need to change them but in all online shops can only find parts for TT Link to comment Share on other sites More sharing options...
Dnk Posted January 30, 2016 Share Posted January 30, 2016 Brake discs will depend on which calipers are fitted, the mkiv has 2 types, 4 pot front 2 pot rears (uk spec) or 2 pot fronts 1 pot rears (j spec) Post a photo of yours as there easily recogniseable, no idea on the cam cover gaskets Link to comment Share on other sites More sharing options...
Bender Posted January 30, 2016 Author Share Posted January 30, 2016 My defo are jspec Link to comment Share on other sites More sharing options...
Bender Posted January 30, 2016 Author Share Posted January 30, 2016 Link to comment Share on other sites More sharing options...
Nic Posted January 30, 2016 Share Posted January 30, 2016 The cam cover seals are the same on the NA and TT, these are the part numbers. The smaller brake discs are: Front: 296.0mm x 32.0mm Rear: 307.0mm x 16.0mm Link to comment Share on other sites More sharing options...
Bender Posted January 30, 2016 Author Share Posted January 30, 2016 The cam cover seals are the same on the NA and TT, these are the part numbers. http://i66.tinypic.com/10rlml4.jpg The smaller brake discs are: Front: 296.0mm x 32.0mm Rear: 307.0mm x 16.0mm http://i65.tinypic.com/23kvyqc.jpg http://i63.tinypic.com/2la4lsw.jpg Great job Nic thank you very much Link to comment Share on other sites More sharing options...
