O/D and slip cont. light flashing ??
dude
Guys help, ive been working on the car , started it up and aside from it running a bit lumpy the O/D off light and Slip cont. off light flash when its running , if i use the O/D switch on the gear lever i can make the O/D off light stay on but not flash , but no matter what i do the slip light stays flashing , heres the work ive done to the car since it was last running (no lights on)
New cam belt /tensioner
uk injectors
fuel regulator (adjustable)
walboro pump
uk resistor box
all turbo pipes removed and polished
new stereo fitted (think i turned ign. on with the top bit dissconected .
removed slip button from normal place and resited .
HEEEEEEEEEEEEELP
John:thumbs:
  Quote
Originally posted by MONKEYmark
dont the lights stay on all time when you pull the trac fuse
if you pull the track fuse i am sure it disable the overdrive fuction.
some brightspark will be here soon
you got it all back together now
Correct sounds like missing or blown TRAC fuse.
I pulled the fuse to check it and it looked ok but i will check it again , when i moved the trac switch i had to cut a wire and extend it , some one had spliced into it and gone off to the fog switch plus the switch doesnt seem to lock in but i would expect the light to stay constant if i held it in .
John:flame Dev
