dude Posted April 6, 2003 Share Posted April 6, 2003 Guys help, ive been working on the car , started it up and aside from it running a bit lumpy the O/D off light and Slip cont. off light flash when its running , if i use the O/D switch on the gear lever i can make the O/D off light stay on but not flash , but no matter what i do the slip light stays flashing , heres the work ive done to the car since it was last running (no lights on) New cam belt /tensioner uk injectors fuel regulator (adjustable) walboro pump uk resistor box all turbo pipes removed and polished new stereo fitted (think i turned ign. on with the top bit dissconected . removed slip button from normal place and resited . HEEEEEEEEEEEEELP John:thumbs: Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted April 6, 2003 Share Posted April 6, 2003 dont the lights stay on all time when you pull the trac fuse if you pull the track fuse i am sure it disable the overdrive fuction. some brightspark will be here soon you got it all back together now Quote Link to comment Share on other sites More sharing options...
dude Posted April 6, 2003 Author Share Posted April 6, 2003 Hey mark its back together except for all my engine bits that went off to the chromer and appear to have gone missing , it started first time as well John:flame Dev Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 6, 2003 Share Posted April 6, 2003 Originally posted by MONKEYmark dont the lights stay on all time when you pull the trac fuse if you pull the track fuse i am sure it disable the overdrive fuction. some brightspark will be here soon you got it all back together now Correct sounds like missing or blown TRAC fuse. Quote Link to comment Share on other sites More sharing options...
dude Posted April 6, 2003 Author Share Posted April 6, 2003 I pulled the fuse to check it and it looked ok but i will check it again , when i moved the trac switch i had to cut a wire and extend it , some one had spliced into it and gone off to the fog switch plus the switch doesnt seem to lock in but i would expect the light to stay constant if i held it in . John:flame Dev Quote Link to comment Share on other sites More sharing options...
eyefi Posted April 6, 2003 Share Posted April 6, 2003 dude, the trac button doesnt lock, press once it goes on press again it goes off. Quote Link to comment Share on other sites More sharing options...
dude Posted April 6, 2003 Author Share Posted April 6, 2003 i will investigate tommorrow , thanks guys . John:flame Dev Quote Link to comment Share on other sites More sharing options...
matt Posted April 6, 2003 Share Posted April 6, 2003 This also happens when the hks trac removal is fitted to the auto. No MANU mode either Quote Link to comment Share on other sites More sharing options...
B3any Posted April 7, 2003 Share Posted April 7, 2003 I had flashy syndrome, somone said it was something to do with the speedo conversion...... Quote Link to comment Share on other sites More sharing options...
dude Posted April 7, 2003 Author Share Posted April 7, 2003 SORTED courtesy of matt harwood , it was the sensor on the throttle body. John:flame Dev Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted April 7, 2003 Share Posted April 7, 2003 Glad to help Quote Link to comment Share on other sites More sharing options...
dude Posted April 7, 2003 Author Share Posted April 7, 2003 Thanks dude. John:flame Dev Quote Link to comment Share on other sites More sharing options...
eyefi Posted April 7, 2003 Share Posted April 7, 2003 Originally posted by Matt Harwood Glad to help yr always helping folk u r Quote Link to comment Share on other sites More sharing options...
tDR Posted April 7, 2003 Share Posted April 7, 2003 He's a very nice man... Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted April 7, 2003 Share Posted April 7, 2003 Grrrrr..... Quote Link to comment Share on other sites More sharing options...
dude Posted April 7, 2003 Author Share Posted April 7, 2003 A 'FLYING' superhero no less. John:p Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted April 7, 2003 Share Posted April 7, 2003 Steady! Quote Link to comment Share on other sites More sharing options...
