No oil pressure light
Bender
Hi for some reason i got no oil pressure light when the key is on position 2. The whole unit was fixed as it had cold solders and was tested on another supra and it works great as soon i connected to my car only had engine menagment light and low oil level light. Anybody had idea how to make it work again ?? image
When I unplugged my oil pressure sensor the other week to test oil pressure. I noticed that the oil pressure light on the dash did not light up when turning the key to ignition. It returned once the sensor was plugged back into the engine loom.
Not sure if you have a GE or GTE, but on the GE the location for the sensor was on the passenger side of the block, located at the front under the intake manifold. Probably worth seeing if you can get your hand on the sensor plug and make sure it is sitting in their firmly.
Thanks i will check that i had GE
Bulbs perfectly fine sensor looks quite ok
That's a strange one then. The sensor shouldn't really come into it as it's a bulb check when you turn the ignition on.... not a sensor check.
The car that you're trying your panel on, can you try it's panel on yours? Just to completely rule out the panel altogether.
