NA-T kit required
mikeekim89
Hello mate, I have a Greddy emanage Ultimate for sale. Perfect for an na t build.
Complete in all the original packaging with a 3 bar map sensor and a plug and play harness.
£600
600 for emanage is over priced. regardless of how new or what packaging it's in. it's still an old ECU. That's standalone money, AEM territory. And no offence, but the packaging won't affect the performance. Please don't try and mug off new owners with no / little experience.
I'm not trying to mug anyone off?
An emanage Ultimate new is £400
A plug and play harness is just shy of another £400
If you think iv over priced something then fine but bearing in mind I'm actually a newer member than mikeekim89 I really don't see what your getting at?
Have a look at the DaveH boostwerx kit or xs power and just swap out the lines and wastegate if your on a budget.
You could also piece your kit together yourself by buying good second hand parts. For example I did mine by buying a sound performance manifold off the US forum, evo injectors, ks racing inlet with NA runners welded on, 4runner dizzy cap, HKS wastegate, garret turbo etc.
Keep an eye out on the US forum too as the conversion is more common there so your more likely to find something there.
