Help with fitting new UK lights
linconhawk
Hi All,
Well, my supras been in storage for about 4 years and now im back...
Back in about 2012 I bought some UK spec headlights from someone on here...
I can kinda remember people saying back then I would need to so something with the wiring as I have a import... anyway, today I started, I have taken one of the lights out and now im stuck... ha ha.
Ive taken some pics, on the new light there is a wiring connector block, there isn't on the old light... ?
connected to my car is a bulb with a blue wire which I cant make out how it comes off..
Please help... I looked in the FAQ and guides but couldn't find anything....
I need a "easy" and "simple" procedure... as im a bit of a novice...
Many thanks
Simply plug and play for the wiring.
The level motors wont work on a Jspec (unless you run some of your own wiring). If your car is a facelift you wont need the side light inside the headlamp unit either.
UK lights also need UK bulbs as the lugs are slightly different or just get a file out and file your lugs.
Brilliant, thanks for the info guys....
A few other things.....
Supplied with my new lights were bulbs, I have 2 x 9005 and 2 x 9006... I presume these are the uk bulbs to go in the new lights....
again, presume the other bulbs remain the same and are a straight swap...
There is the one with the blue wire.... Remains the same ?
There is another one in a long holder, remains the same ?
cant remember what else there was.... too dark to look now....
May sound silly, but what buld i.e 9005 / 9006 goes in what hole on the actual light ???
One last thing, the 2 little nuts that hold the side of the light in, anyone know what size nut I need ?? my lights were only held in with one, so I need to buy some in the morning...
Thanks so much !!!
