1995 Toyota Supra UK 6 Speed - Single turbo conversion with Built Engine
Sheefa
Hi
Unfortunately it has been confirmed today that my role is "at risk" and no longer exists in the new structure after 9 years with the company. Whilst I will be entitled to a healthy redundancy package, I have just taken delivery of my new BMW 335 Touring under contract and therefore I cannot justify keeping the Supra at this unsettling time with a young family to care for.
I purchased the car only in October 2015 off a member from here who owned it for 15 years! He bought it from Toyota and I have the old warranty, service book etc and confirmation slips.
The car has now covered just over 90,000 miles.
The car went to SRD in October 2015 for a lot of work and full servicing (at a cost of £4K with new suspension) bringing her up to a near new standard. This included:
New HKS HyperMax IV Suspension
Brand New OEM Fuel and Brake Lines
New Toyota Timing Pulley, Toyota Belt Idler and Gates Kevlar Racing Belt
New PHR Idler Pulley
New Walbro 485 Pump & Fuel Setup
DEI T4 Titanium Heat Shield Turbo Blanket & DEI Titanium Exhaust Wrap for Downpipe
New SRD Turbo Oil Feed and SRD Turbo water line kit
Full Service with Brake, Oil, Fuel Filter and Fluid changes
Actual Spec as follows:
Engine
The engine has been built specifically for high HP and high temps, balanced; compression is in spec and almost identical across all cylinders (189 across 5, number 5 at 183). Fully Built and balanced engine & Head with less than 10K miles.
HKS (Carrillo) rods
Oversize CP Piston and Ring Set (3.1 litres)
New crank
HKS 256 Inlet cam
HKS 264 outlet cam
Ferrea Ti retainers
Polished Q45 throttle body, manifold and cam covers.
Engine Components
Boost Logic crank pulley and Crank Damper
Alloy pulleys
Gates Racing Kevlar Cam belt
New OEM flywheel
New Toyota Belt Idler
PHR Idler Pulley
Modifed oil pump.
Turbo Kit
Powerhouse Racing Stage 3 72mm dual ball bearing Turbo Kit
HKS ceramic coated manifold
New SRD turbo water line and oil line kit
DEI T4 Titanium Turbo Blanket
DEI Titanium Heat wrapped PHR 4” ceramic coated downpipe/midpipe
Dual HKS BOV’s
Fuel System
850CC Fuel injectors
New OEM Fuel lines
New Walbro 485 pump
Stock Rail
Aeromotive Fuel Pressure Regulator
Exhaust
Veilside 4" Titanium exhaust (with optional bung)
Cooling
GReddy 4row Intercooler with hardpipes
10 row power steering cooler
16 row Oil Cooler
New Rear diff cooler
Custom Airbox
PWR Polished Aluminium Radiator with twin electric fans (ECU Controlled)
Electronics and control
Syvecs S6 ECU (Tuned by Ryan@2BAR)
Innovate Motorsports Wideband (ECU Connected)
New Coil packs
Enhanced Knock sensors (ECU monitored)
Oil pressure probe (ECU monitored)
EGR probe (ECU monitored)
Boost control valve (ECU controlled and monitored)
Laser Line Cat 1 Thatcham approved Car alarm
Transmission
Stock Getrag V160 6 speed Manual (Smooth as silk)
Uprated six puck metallic clutch
AP Engineering Shifter Bushing Kit
Modified clutch slave cylinder & braided line
New OEM Toyota flywheel
Suspension
New HKS HyperMax IV Suspension (Awesome ride and comfort, fully adjustable)
TRD Anti-roll bars
Full Geometry setup completed at fitment by SRD in November 2015
Wheels & Braking
18” CCW Classic Wheels with chrome lip and Matt centre finish complete with caps
New Toyo Proxe T1-R tyres
Upgraded steering rack bushes
UK Spec brakes with full braided stainless, coated hoses
New OEM brake lines.
Interior
TRD 10K tech Speedo
Toyota Celica steering wheel and ABS connector
MVP Aluminium pedals
MVP Aluminium dial surround
Sparco Milano Prestige leather seats
Bride seat rails
Leather gear and handbrake covers
Pioneer Double DIN DVD, Ipod and MP3 head unit with Rear View Camera functionality
Kenwood amp & lightweight speakers.
Bodywork
Stock OEM bodywork
Whifbitz lower lip with 2” hose pickups
Facelift Front Indicators
Clear Side Repeaters
Rear Lights Clear Indicator Lenses
Glass UK Spec Headlights
Other Fancy bits
Carbon Fibre Engine Cover
SRD Aluminium Under tray
SRD cooling plate
Aluminium Rad overflow tank
Chromed Top radiator hard pipe
Whifbitz carbon fibre bonnet dampers
Whifbitz billet radiator brackets
Looking for £19k for what is a near pristine 6 speed UK Manual Single Turbo with a fully built engine. The U.K. Specs especially in manual form are getting extremely rare now, I actually bought this as an investment. I believe there are only 3 UK Spec Silver Manual Cars left, certainly logged on here anyway. Prices are only going one way, especially for home grown UK Supra's.
Photos to follow but please see here for links and more details.
http://www.mkivsupra.net/vbb/showthread.php?328523-It-feels-SO-good-to-be-back-)-UK-Spec-Built-Engine-6-Spd-Manual-Single-Turbo-Supra
http://www.mkivsupra.net/vbb/showthread.php?325627-*UK-Spec-6-speed-Single-Turbo-built-engine*
Please PM me in the first instance and I'll come back to you.
Regards
Greg
Love this car. Does is still have the piston slap?
Let's not go through this debacle again like the other thread! Lee @ SRD checked it over and all is absolutely fine. Compression test was great and honestly you can hardly tell it's a built engine. A little piston slap with oversized Pistons is entirely normal and I strongly suggest and urge people to read through the threads and more about piston slap in general before being put off by this comment. Happy to also get videos up too.
Here is a link to a cold startup I've just recorded.
Owwwwww maayynnnnn, no more car meets :( Really sorry to hear this mate.
For anyone considering buying this, I've been out in it and seen it in the flesh and it's absolutely mint, beautiful condition with a gorgeous looking engine bay and it goes like stink :)
Sorry to hear this has to happen mate, but GLWTS.
Seeing as a stock UK spec manual in this condition with this mileage would probably be worth £15k - £17k, this seems way to cheap, especially considering some of the parts fitted (the CCW's and Syvecs especially)
Personally, I'd either stick the price up another £2k, or at least fit some different wheels and sell the CCW's separately. I suppose the only issue is that there are quite a few nice singles for sale at the moment.
GLWS.
Thanks all, most appreciate the kind words.
The car is stunning and completely Stock on the outside except the Whifbitz Front Lip. I've just repainted all of the U.K. Brakes. The car doesn't need or want anything else. She is 100% ready to go.
I am only gauging interest at present and will also do so on the wheels in a separate for sale thread here:
http://www.mkivsupra.net/vbb/showthread.php?330250-Only-Gauging-Interest-Genuine-CCW-BS-Titanium-Street-Wheels-MINT-condition
Thanks
Greg
Love this car. Does it still have the piston slap?
There is no issues with the engine.
The previous owner mentioned the noise on the last for sale thread but it's perfectly normal for these aftermarket pistons.
Compression test is perfect and no smoke at all. Very strong engine
Thanks Lee. No better testament than from SRD.
Good to know, I should have read the other thread! Cheers Lee
Thanks again guys. I'm still in two minds about doing it but I have to cover my back in case the worst happens and I don't land a job end of March. Please note for prospective buyers, this is only provisionally for sale. I won't be able to accept any deposit until February.
Hmmm, wanted this the first time around when Lee advertised it! ;)
Wonder if I can find a buyer for my IS-F?! :search:
Sorry to hear your having to sell it Greg. Looks like you've made it even better in your brief ownership! :cool:
Great car at a great price IMHO.
Really hope it finds a loving home. Don't sell the wheels!! They so make this car. ;)
Cheers.
Peter :)
Cheers.
Peter :)
Thank you Peter. The wheels will be staying with the car now.
Provisionally SOLD to 88Le awaiting outcome of my job.
It's complete with all the original manuals, warranty details and other paperwork!
[ATTACH=CONFIG]208391[/ATTACH]
Guest knebworth01
Well done on the sale, great looking car and clearly had money lavished on it!
I must say, I don't know where people get off on posting negative comments about a car when you're trying to sell it (piston slap). Keep your nose out if you've got nothing positive to add I say!
No longer for sale as lined myself up another job and redundancy package is awesome!
Nice! :cool:
Pleased for you Greg. :thumbs:
Glad your able to hold on to it. Based on the videos of you guys giggling, think you have lots more fun to have with this beauty. ;):D
Look forward to seeing what else you have planned for the future. :cool:
