Supra at Whifbitz for 7 Speed DCT PT6266 GEN2 Single Turbo Conversion
scott.wild
After having the full respray complete the car is now at Whifbitz for the conversion :)
Whifbitz 7 Speed DCT gearbox conversion
Whifbitz billet single turbo conversion using a PT6266 Gen 2 turbo
Whifbitz top feed fuel injector conversion with Asnu 850cc injectors
Fuelab FPR
Walbro 450LPH fuel pump
Whifbitz 264 cams
Valve stem seals replaced
Whifbitz 25 row oil cooler kit
Polished turbo housing, cam covers and inlet manifold
Cambelt, tensioners and water pump
More details and pictures to follow
  • Replies 109
Hi Scott :) Looking forward to seeing how this turns out :cool:
If you want to make the pictures bigger, upload them to photobucket. Once on there, go to the image links area by each picture, copy the 'direct' link, and come back on to the forum. Press the 'insert image' button on the top bar of the posting box, then paste the link into the box on the 'from URL' tab. You will see an image code appear on your posting box ------. when submit the post, the picture will now be displayed at full size :)
Look forward to how this one turns out. Very good setup choice.
No need to upload to photobucket for bigger pics btw (you need to have them on the site for your thread to be changed to a project thread) simply use ] tags as suggested instead of "[attach"
