Engine bay corner covers
Scott
Do we have anyone that makes/supplies these? No idea what to search for to be honest so I've had no luck digging around. Looking to buy a couple of the corner covers to cover over the brake reservoir/charcoal canister area.
  • 1 year later...
Just bumping this as it appears SRD don't do them anymore and the ones from charge auto styling require a fair amount of modification. Does anyone know of anyone else who does these?
I noticed the OCD works ones but they are from the US and cost over $1000 without shipping and tax
Edited by JasonR24 (see edit history)
Tim @ TB Developments (a trader on here) can make them to order
Brilliant, cheers mate
They dont require "that much" modification, give it a go!
Well from what he told me on Facebook:
"You'll need to lower or remove the charcoal canister.
Move the ignitor to where the charcoal canister was, or by the abs pump. It's also a good idea to pull the loom from the passenger side inner wing, and feed it around the shock tower, so it's out of the way.
The loom on the driver side inner wing, simply unclips, and can be fed round the shock tower, behind the turbos.
The heater hoses at the back may need tidying up, to allow the centre piece to sit over them.
The panel will need trimming to clear the stock inlet manifold - you may be able to see in my pic.
I'm not sure about clearance on the stock turbo setup, but I'd imagine the driver side panel will also need to be trimmed to clear.
The throttle cable can be unclipped, and fed behind the brake servo, and them back across to the throttle body"
They do look really really good but I feel they aren't really for the stock setup and I'm not comfortable trimming carbon as I know I'd mess it up :(
Gary England on Facebook makes carbon ones :)
I think those are the charge auto styling ones?
Bit of inspiration for you :D
Jeffers did my two outter metal covers to help me out, he did say he wouldn't be doing another set though as they proved him alot of headache....mainly as I wanted smooth welds.
Superb work though, fit great dropped straight in with no modification.
We are still doing engine bay boxes but we are currently tweaking the design so they fit better which is why they havent been around.
Will be ready to go in the next couple of weeks
will update he thread with details and pricing when ready
Another option I was looking at was using Nimbus Lite Heat Shield
http://www.demon-tweeks.co.uk/motorsport/heat-shielding-protection/nimbus-lite-heat-shield
Oddly enough I have just received a sheet of exactly that.
I was planning on shaping it to protect a cold air feed from heat from an aftermarket manifold, I'm sure it can be worked to make some kind of engine bay box/cover, as per here:
http://www.mkivsupra.net/vbb/showthread.php?302082-Axle-Destroyer-3-4-Titan-Stroker/page21
I am looking at Garys , I like the shape but alot of work to get them to fit an OEM setup
At least the Nimbus Lite Heat Shield you might be able to tweak fairly easily , be nice painted satin black with the Diamond cut design
Keep us posted on how easy it is to work with, shape and cut , might try make up a template the weekend
Will do. I've got a 1m x 1m sheet (not cheap) but plenty to play with.
I trimmed my carbon boxes and slam panel with a dremel and it was easy as hell. Just take your time.
