evinX Posted January 19, 2016 Share Posted January 19, 2016 My Supra may be in need of some suspension parts as it has a knock so ill be investigating this over the weekend no doubt in the cold & wet So these could be the cause, Upper control arm - Stupidly priced by Toyota, but the noise I'm getting isn't like a busted knuckle sound Rear drop links - always thought these would need changing anyone used these? seem well priced http://www.ebay.co.uk/itm/Supra-JZA80-3-0-Turbo-None-Turbo-Rear-Drop-Links-x-2-/360847639305?hash=item5404320309:g:43gAAOxydlFS5~UJ Or any other links to blue print/ well priced drop links? cheers, Kev Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 19, 2016 Share Posted January 19, 2016 IIRC the drop links from MrT are not to expensive anyway, Id go OEM Quote Link to comment Share on other sites More sharing options...
Scooter Posted January 19, 2016 Share Posted January 19, 2016 Are your shocks original? Quote Link to comment Share on other sites More sharing options...
evinX Posted January 19, 2016 Author Share Posted January 19, 2016 Are your shocks original? KYB gas adjusts, all round and fitted recently. I had the dreaded knock from my old shock, but this is definatley a metallic thud I'm getting this time Quote Link to comment Share on other sites More sharing options...
evinX Posted January 26, 2016 Author Share Posted January 26, 2016 Bumping this, thought it might be helpful to other members. Ordered me some Febi Bilsteins, my mechanic has used their parts any times so decided to use these, much cheaper than Toyota. Any where I can, I use aftermarket OEM brands that make quality products as imo Toyota are a little high. Rear drop link RH - Febi Bilstein 42959 - Toyota 48830-14050 Rear drop link LH - Febi Bilstein 42966 - Toyota 48840-14030 http://www.ebay.co.uk/itm/311485213614?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT http://www.ebay.co.uk/itm/191738124695?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Kev Quote Link to comment Share on other sites More sharing options...
Scooter Posted January 26, 2016 Share Posted January 26, 2016 Let us know how you get on and it they cure your noise Quote Link to comment Share on other sites More sharing options...
evinX Posted January 28, 2016 Author Share Posted January 28, 2016 Let us know how you get on and it they cure your noise Had a the car checked out, the rear left was knackered, could move it by hand. Replaced today and the knock has gone. Well happy. Googled images of the febi drop links compared to Toyotas and they look exactly the same build wise. Going to do the fronts in the summer as is cheap enough to Quote Link to comment Share on other sites More sharing options...
jim Posted January 28, 2016 Share Posted January 28, 2016 I've bought those drop links from that seller for my previous supra, the place is only a few miles away from where I live - they were spot on Quote Link to comment Share on other sites More sharing options...
JackyBoi Posted January 28, 2016 Share Posted January 28, 2016 I also have a thud/knocking noise coming from my rear left suspension. Whifbitz fitted a new upper arm but it didn't do anything. Could it be the drop links? Quote Link to comment Share on other sites More sharing options...
David P Posted January 28, 2016 Share Posted January 28, 2016 Could be dodgy drop-link or a failing shock absorber? Quote Link to comment Share on other sites More sharing options...
ben_harmer32 Posted January 28, 2016 Share Posted January 28, 2016 I'm guessing they shouldn't move at all then? I can wriggle mine side to side by hand I also have a knock from the rear. Quote Link to comment Share on other sites More sharing options...
Scooter Posted January 28, 2016 Share Posted January 28, 2016 no they do move like that I think as they are ball jointed both ends....it's if the actual joins are worn that the knock (again I think) and I'm not sure if you can tell that by hand with them joined to the anti roll bar and so in tension/compression. Quote Link to comment Share on other sites More sharing options...
JackyBoi Posted January 28, 2016 Share Posted January 28, 2016 Could be dodgy drop-link or a failing shock absorber? The old rear left shock was knackered, fitted new BC Racing coil overs and upper arm at the same time, knock is still there Quote Link to comment Share on other sites More sharing options...
welshboy Posted January 28, 2016 Share Posted January 28, 2016 I may as well do these whilst replacing the shocks. Cheers for the links (again) Quote Link to comment Share on other sites More sharing options...
evinX Posted January 29, 2016 Author Share Posted January 29, 2016 I may as well do these whilst replacing the shocks. Cheers for the links (again) No probs at all I get slight knocks on dirty bumps/holes and ill be looking at doing the bushings/rubbers under the car next as alot of them are starting to perish Quote Link to comment Share on other sites More sharing options...
EdMorris Posted January 31, 2016 Share Posted January 31, 2016 Hmm, these are a lot cheaper than OEM. Quote Link to comment Share on other sites More sharing options...
evinX Posted February 1, 2016 Author Share Posted February 1, 2016 Hmm, these are a lot cheaper than OEM. Significantly cheaper! I'm going under the car today (hopefully) and if I remember ill snap a shot of them fitted for you all to see. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted June 21, 2017 Share Posted June 21, 2017 How you getting on with these Kev? I got a pair of new drop links that aren't Toyota and not keen on fitting them. These seem good for the price. Interested to hear your experience with them. Quote Link to comment Share on other sites More sharing options...
evinX Posted June 21, 2017 Author Share Posted June 21, 2017 No probs at all. 2 mots since they were fitted and they still have a shine to them Quote Link to comment Share on other sites More sharing options...
