Jezz Posted January 18, 2016 Share Posted January 18, 2016 Last night something weird happened with my autobox. No warning signs or previous issues. After changing up into 4th (OD on), it made a slight whirring type noise and felt like extreme engine braking when I lifted off. Almost as if the handbrake was on. I stopped and let it go up through the gears, all gears are fine with no noise apart from 4th, it felt hesitant and made the whirring noise again but only with OD on. Click it off and it's fine in 3rd. A little further toward home and I've now lost 4th (OD) altogether. No codes, no flashing OD light, just no OD! Fluid is fine level wise, doesn't look burnt. All other gears are still fine and whisper quiet. Any ideas? Never had an NA autobox fail on me! Quote Link to comment Share on other sites More sharing options...
Scooter Posted January 18, 2016 Share Posted January 18, 2016 I can only think to drain the 2L sump and check for debris? Quote Link to comment Share on other sites More sharing options...
Jezz Posted January 18, 2016 Author Share Posted January 18, 2016 I can only think to drain the 2L sump and check for debris? That's the plan. Just going to drain it off now. I'm now getting a slight drop in revs (4-500rpm) when I click OD on but it still feels like its pulling back. Puzzled. Quote Link to comment Share on other sites More sharing options...
David P Posted January 18, 2016 Share Posted January 18, 2016 It could be a sticky solenoid or a dicky signal to a good one. Quote Link to comment Share on other sites More sharing options...
Jezz Posted January 18, 2016 Author Share Posted January 18, 2016 It could be a sticky solenoid or a $#@!y signal to a good one. Anyway I can test them David? Nothing in the fluid, nice and clean. 2L out, fresh 2L back in, blasted to Kettering and back with no difference. Quote Link to comment Share on other sites More sharing options...
David P Posted January 18, 2016 Share Posted January 18, 2016 (edited) First check that the correct on/off signals are going to the solenoids, info in Workshop Manual, if not the problem, drop the sump, take out the solenoids and test them. Edited January 18, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Jezz Posted January 18, 2016 Author Share Posted January 18, 2016 First check that the correct on/off signals are going to the solenoids, info in Workshop Manual, if not the problem, drop the sump, take out the solenoids and test them. Thanks mate, will take a looky and drop the pan over the weekend. Quote Link to comment Share on other sites More sharing options...
David P Posted January 18, 2016 Share Posted January 18, 2016 (edited) This link will lead Club members to a link with the answer to anything they might need to know. Supra Automatic Transmissions - The Answer to Everything Edited January 18, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted January 18, 2016 Share Posted January 18, 2016 Workshop manual may also help http://www.mkivsupra.net/vbb/content.php?53-Automatic-Transmission-(2JZ-GE) Quote Link to comment Share on other sites More sharing options...
Jezz Posted January 18, 2016 Author Share Posted January 18, 2016 Workshop manual may also help http://www.mkivsupra.net/vbb/content.php?53-Automatic-Transmission-(2JZ-GE) Got that Nic cheers. Quote Link to comment Share on other sites More sharing options...
David P Posted January 18, 2016 Share Posted January 18, 2016 Workshop manual may also help http://www.mkivsupra.net/vbb/content.php?53-Automatic-Transmission-(2JZ-GE) Should you care to look, that mere snippet of information is included in the Supra Automatic Transmissions - The Answer to Everything link. Quote Link to comment Share on other sites More sharing options...
evinX Posted January 19, 2016 Share Posted January 19, 2016 Id go with DavidP's advise, I thought mine was knackered and he sorted it thanks David Quote Link to comment Share on other sites More sharing options...
Jezz Posted January 19, 2016 Author Share Posted January 19, 2016 Id go with DavidP's advise, I thought mine was knackered and he sorted it thanks David http://i51.photobucket.com/albums/f361/trinidadianstallion/20150919_120844_zpso4afnqwb.jpg Typical that I probably threw 20 of these away when I was in the game! It's the one thing I've never had to get involved with. How much did David charge? I'm only up the road. Quote Link to comment Share on other sites More sharing options...
evinX Posted January 20, 2016 Share Posted January 20, 2016 Typical that I probably threw 20 of these away when I was in the game! It's the one thing I've never had to get involved with. How much did David charge? I'm only up the road. Pm him and find out, if you guys wana meet up and mess around with supras im in. Need to jack mine up and find my rear knock this weekend Quote Link to comment Share on other sites More sharing options...
David P Posted January 20, 2016 Share Posted January 20, 2016 Try an ECU swap, it's the easiest thing to cross off the list. If that doesn't help, follow the O.D. diagnostics in WSM. Quote Link to comment Share on other sites More sharing options...
Jezz Posted January 20, 2016 Author Share Posted January 20, 2016 Try an ECU swap, it's the easiest thing to cross off the list. If that doesn't help, follow the O.D. diagnostics in WSM. Thanks for the advice and chat today David. I swung by Silverstone to grab another ecu, i'll give that a whirl when I'm off work, failing that I'll try the next step. Quote Link to comment Share on other sites More sharing options...
Jezz Posted February 1, 2016 Author Share Posted February 1, 2016 Update on this. I found my overdrive!... There it is, those shards of metal just there. Quote Link to comment Share on other sites More sharing options...
David P Posted February 1, 2016 Share Posted February 1, 2016 Quote Link to comment Share on other sites More sharing options...
David P Posted February 1, 2016 Share Posted February 1, 2016 The strainer has done it's job and the valve body is still working okay, clean up that box I gave you, swap the bits over and fit a new strainer. Quote Link to comment Share on other sites More sharing options...
Jezz Posted February 1, 2016 Author Share Posted February 1, 2016 The strainer has done it's job and the valve body is still working okay, clean up that box I gave you, swap the bits over and fit a new strainer. I fitted a complete box earlier, drives lovely again. I'm going to strip down the old one and take the valve body out to try and find out how a bog standard NA has lunched its transmission! Quote Link to comment Share on other sites More sharing options...
David P Posted February 1, 2016 Share Posted February 1, 2016 (edited) Put the valve body in a carrier bag to keep it clean, that'll come in handy. P.S. Be careful not to break the sandwich gasket around the actuator tops. Edited February 1, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Konrad Posted February 1, 2016 Share Posted February 1, 2016 Pm him and find out, if you guys wana meet up and mess around with supras im in. Need to jack mine up and find my rear knock this weekend I guess subframe bolts need to be set to proper torque or one of the rubbers need changing Quote Link to comment Share on other sites More sharing options...
David P Posted February 1, 2016 Share Posted February 1, 2016 (edited) I guess subframe bolts need to be set to proper torque or one of the rubbers need changing Have your goggles misted up? Edited February 1, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Konrad Posted February 3, 2016 Share Posted February 3, 2016 Check a quote above my answer and clean yours ;-) Quote Link to comment Share on other sites More sharing options...
David P Posted February 3, 2016 Share Posted February 3, 2016 Check a quote above my answer and clean yours ;-) Right quote, wrong thread. Quote Link to comment Share on other sites More sharing options...
