Top Feed vs Side Feed Injectors
Noz
Are the connectors the same on the GE and GTE? I know the variation of side feed vs top feed varies between the two.
Unsure also about the dimensions, but looking to upgrade the GE injectors and thinking perhaps a set of top feed GTE injectors would suit. Even if I need adapters on the runners or fuel rail bore size.
I read somewhere that side feed injectors usually only go upto around 850cc, is that perhaps due to the sudden change of fuel direction in a side feed rail?
