Plasti Dip on interior elements
Bender
I'm doing this today. Never done it before but hoping it will turn out ok. Haven't managed to take out the painted bit on the drivers door. Where the window switches are. Do you have to undo any bolts or is it just a matter of pulling hard enough?
You need to remove the door pad and unscrew in from behind..
Cheers!! I get it by door pad you mean the armrest?
Just did the final coat, will leave it to dry for 3-4 hours and get some pictures then. The texture looks very OEM. Very pleased. Did no prep at all except cleaning the panels so I can easily remove it if it doesnt come out as I want. Very easy.
No, the entire door card..
