CASHEYE Posted January 15, 2016 Share Posted January 15, 2016 I took my door cards off the other day and it looks as if rain has been getting in though the seal. When the doors are open the windows leans in towards the car and leaves a gap of about 3mm between the seal. I've never noticed this before, but then I've never had the need to look either. The moisture barriers are still on, albeit not completely attached all the way round, but I can't see how any water gets out though the bottom of the door. Maybe it isn't the rain that's getting in (there isn't really any gap between the seals and the windows when the doors are closed) and this time of year there's just a build up of moisture in the car. I did see someone else posted about excessive moisture on the rear windscreen and to put some absorbent packs in the car so maybe I'll try that. The door cards don't seem damaged. They're still quite ridged along the bottoms but I just wondered if anyone else has noticed this before? I've also seen that people have just removed the moisture barriers all together. Obviously they're there for a reason, but are they that effective? Quote Link to comment Share on other sites More sharing options...
Nic Posted January 15, 2016 Share Posted January 15, 2016 I had the same problem years ago, new window seals solved the problem. Have you tried removing the door cards and pouring water on the window to see where it's coming in? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 15, 2016 Share Posted January 15, 2016 I had the same problem years ago, new window seals solved the problem. Hey Nic. Door window seals or the ones actually on the fixed in windows? - - - Updated - - - Obviously they're there for a reason, but are they that effective? They help stop the door cards getting damp and mouldy. A previous supra I had didn't have them and suffered from this. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 15, 2016 Share Posted January 15, 2016 (edited) Hey Nic. Door window seals or the ones actually on the fixed in windows? Hi Pete, it was the window seal along the top of the door I replaced that made the difference and stopped the water getting into the door behind the door card.I think I also replaced the door seals at the same time which stopped the wind noise/draft I was getting. Edited January 15, 2016 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
CASHEYE Posted January 17, 2016 Author Share Posted January 17, 2016 Well I checked and I can't see how it's getting in. The seals at the top of the window are sound and when the door is closed everything is tight. I'll just choke it up to the insanely damp weather and check it again soon. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 17, 2016 Share Posted January 17, 2016 Well I checked and I can't see how it's getting in. The seals at the top of the window are sound and when the door is closed everything is tight. I'll just choke it up to the insanely damp weather and check it again soon. You could try using a silicone spray on the seals and bending them over whilst the window is down, this should soften the seals and may help them to seal better. If you are getting water inside the door though you run the risk of rust developing, I know on mine the only way I could get them to seal was with new seals. Quote Link to comment Share on other sites More sharing options...
CASHEYE Posted January 17, 2016 Author Share Posted January 17, 2016 I'll give that a whirl. If it still persists I'll see about ordering some new one. Thanks for the part numbers. Quote Link to comment Share on other sites More sharing options...
