a98pmalcolm Posted January 14, 2016 Share Posted January 14, 2016 I was wondering if anyone has a simlar issue with there rear window. I get excessive moisture that builds up in no time. At times it even has water drips that run down it from so much moisture build.up. Quote Link to comment Share on other sites More sharing options...
Slam Posted January 14, 2016 Share Posted January 14, 2016 Boot or window seal. Is there water in boot wells. Do you have a boot spoiler. Quote Link to comment Share on other sites More sharing options...
evinX Posted January 14, 2016 Share Posted January 14, 2016 Yea mine has it to, its only down to the weather at the moment, if I use my rear demister theres more water. Every few days I just get the cloth on it. Normal stuff matey Quote Link to comment Share on other sites More sharing options...
mc92 Posted January 14, 2016 Share Posted January 14, 2016 You want a couple of these in the car, I've got one in mine and it soaks up loads of moisture from the air. It used to fog up really quickly in the mornings but now it barely does it at all. http://www.amazon.co.uk/dp/B005MZ1EJE/ref=sr_ph?ie=UTF8&qid=1452796431&sr=1&keywords=dehumidifier Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 14, 2016 Share Posted January 14, 2016 I think it is caused by the seals and moisture barriers ageing. But as suggested, using moisture traps and cleaning the glass regularly will help Quote Link to comment Share on other sites More sharing options...
trebor69 Posted January 14, 2016 Share Posted January 14, 2016 My rear window fogs up rather quickly too and one thing I'm going to check is the footwell under the carpet just to rule out the heater matrix seeping warm water into the car. Quote Link to comment Share on other sites More sharing options...
jim Posted January 14, 2016 Share Posted January 14, 2016 For a diy moisture trap, a sock filled with cat litter and tied at the top will do the same job Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted January 14, 2016 Share Posted January 14, 2016 Must be those amazing ford seals you fitted eh Quote Link to comment Share on other sites More sharing options...
JackyBoi Posted January 14, 2016 Share Posted January 14, 2016 You want a couple of these in the car, I've got one in mine and it soaks up loads of moisture from the air. It used to fog up really quickly in the mornings but now it barely does it at all. http://www.amazon.co.uk/dp/B005MZ1EJE/ref=sr_ph?ie=UTF8&qid=1452796431&sr=1&keywords=dehumidifier Those look brilliant! Just bought 2. My Audi may as well be a steam room Quote Link to comment Share on other sites More sharing options...
Big Supes Posted January 14, 2016 Share Posted January 14, 2016 Is your car your daily? Moisture can build up over time when its sat around. Whenever I run my car up I hit the AC on recirc to get rid of the moisture while keeping the AC healthy. Quote Link to comment Share on other sites More sharing options...
berg Posted January 14, 2016 Share Posted January 14, 2016 Mines the same Today for example my rear screen looks white where its condensated, been like it all day Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted January 14, 2016 Author Share Posted January 14, 2016 You want a couple of these in the car, I've got one in mine and it soaks up loads of moisture from the air. It used to fog up really quickly in the mornings but now it barely does it at all. http://www.amazon.co.uk/dp/B005MZ1EJE/ref=sr_ph?ie=UTF8&qid=1452796431&sr=1&keywords=dehumidifier Thanks mate just ordered some Quote Link to comment Share on other sites More sharing options...
mellonman Posted January 15, 2016 Share Posted January 15, 2016 It could also be the sills / seen around the rear lights leaking be covered before . Take out the boot plastics and poor water down the boot gutter and see if it leaks Quote Link to comment Share on other sites More sharing options...
