Test fitted the Work Meister SP1's
Chris Bailey
Managed to find some time at the weekend to test fit the new wheels, after spending months trying to find out sizes and offsets that would fill the arches and clear the UK brakes it was a nervous moment. Very pleased with how they have turned out, we've got to have the front wheel studs cut down or replaced as we had to have longer studs for the old wheels. Also in the picture we still had the 10mm spacer on the front hence why its sticking out a touch. But gives a rough idea how they will look. Hopefully going to lower the car a little aswell. imageimageimageimageimageimageimageimageimage
Amazing wheels, been waiting to see how they'd look on the car, fitment looks spot on :cool: is it sitting high because it had been jacked up, will the height settle?
I pulled the trigger on a set of SSR Professors on Saturday :D
It may be sitting high because we had it jacked up to swap the wheels over im not sure, do coilovers settle if the car has been jacked up? The ride height will be adjusted once the wheels are on.
