jza800 Posted January 9, 2016 Share Posted January 9, 2016 I am after a new set of gauges to my car. it have to be electric gauges, who is the best you can get? defi autometer drift prosport ect ect Oil pressure Oil temp Turbo water Link to comment Share on other sites More sharing options...
johnny g Posted January 9, 2016 Share Posted January 9, 2016 Syvecs + Toucan, if price is no object. Link to comment Share on other sites More sharing options...
Tsia Posted January 9, 2016 Share Posted January 9, 2016 Got Defis myself, the quality is a bit questionable for the price, so if you can get a used set they're pretty good. The control box is a nice feature, being able to do a pull and record/replay the gauges can be useful sometimes. They look the part, too. Link to comment Share on other sites More sharing options...
j_jza80 Posted January 9, 2016 Share Posted January 9, 2016 Defi gauges are lower end mainstream. If you want the best, then buy STACK Demon Tweeks sell the full range. They fo a pretty trick professional range oil pressure gauge, that can activate an alarm or control a relay if oil pressure goes out of the pre defined points However, STACK gauges are expensive. Link to comment Share on other sites More sharing options...
jza800 Posted January 9, 2016 Author Share Posted January 9, 2016 Ok i have prosport evo gauges now, but they have 0.5 bar misreading, so what a gauge set, that dont have so much misreadings.. Link to comment Share on other sites More sharing options...
Tsia Posted January 9, 2016 Share Posted January 9, 2016 Ok i have prosport evo gauges now, but they have 0.5 bar misreading, so what a gauge set, that dont have so much misreadings.. Some of their gauges are really good, so it's odd to hear that. My old MR2 had them, I plumbed in a Defi and had my Blitz boost controller - the Prosport was perfectly matched with the controllers readout. Link to comment Share on other sites More sharing options...
j_jza80 Posted January 9, 2016 Share Posted January 9, 2016 http://www.stackltd.com/ Link to comment Share on other sites More sharing options...
jza800 Posted January 9, 2016 Author Share Posted January 9, 2016 Some of their gauges are really good, so it's odd to hear that. My old MR2 had them, I plumbed in a Defi and had my Blitz boost controller - the Prosport was perfectly matched with the controllers readout. Yes i had that impression too, but had a manual oil pressure gauge on too, and could see that there was 0.5 bar in diffence Link to comment Share on other sites More sharing options...
zaheer0027 Posted January 10, 2016 Share Posted January 10, 2016 Aem is an option Link to comment Share on other sites More sharing options...
jza800 Posted January 10, 2016 Author Share Posted January 10, 2016 Aem is an option yes but they dont read in bar... only psi Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 10, 2016 Share Posted January 10, 2016 yes but they dont read in bar... only psi Their analog gauges have an option of coming in bar. Link Link to comment Share on other sites More sharing options...
jza800 Posted January 10, 2016 Author Share Posted January 10, 2016 Their analog gauges have an option of coming in bar. Link yes i now that, but as i have their aem air/fuel gauge with digital, i like to have the same design all the way Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 10, 2016 Share Posted January 10, 2016 GEMS CD24 colour display. You did say cost no object.... Perfectly readable in direct sunlight. Simply the best display panel on the commercial car market. http://shop.rdt.tv/index.php?app=gbu0&ns=prodshow&ref=GEMS_DISPLAY_CD24&sid=e4ya99z6z69w9g4z7dfv86718hx8875q At the other end of the spectrum are those simply dire DEFI things. But to be honest you are FAR better with analogue gauges IMHO. Link to comment Share on other sites More sharing options...
jza800 Posted January 10, 2016 Author Share Posted January 10, 2016 GEMS CD24 colour display. You did say cost no object.... Perfectly readable in direct sunlight. Simply the best display panel on the commercial car market. http://shop.rdt.tv/index.php?app=gbu0&ns=prodshow&ref=GEMS_DISPLAY_CD24&sid=e4ya99z6z69w9g4z7dfv86718hx8875q At the other end of the spectrum are those simply dire DEFI things. But to be honest you are FAR better with analogue gauges IMHO. yes chris i now i an way better with analogue gauges, but i dont like the idea off haveing oil + fuel runing inside the car to the gauges... Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 10, 2016 Share Posted January 10, 2016 You need to have neither, in fact international motorsport regulations prohibit it. You can buy off the shelf gizmos that act as a barrier to no fuel or hot oil can escape in the car if a line is damaged or comes loose. One example: https://www.merlinmotorsport.co.uk/p/fuel-pressure-gauge-isolator-rta700?utm_source=Google&utm_medium=ShoppingUK&utm_campaign=ShoppingUK&vat=on¤cy=GBP&gclid=CPCo_aX8n8oCFQcYwwodjlQCXg Link to comment Share on other sites More sharing options...
jza800 Posted January 10, 2016 Author Share Posted January 10, 2016 You need to have neither, in fact international motorsport regulations prohibit it. You can buy off the shelf gizmos that act as a barrier to no fuel or hot oil can escape in the car if a line is damaged or comes loose. One example: https://www.merlinmotorsport.co.uk/p/fuel-pressure-gauge-isolator-rta700?utm_source=Google&utm_medium=ShoppingUK&utm_campaign=ShoppingUK&vat=on¤cy=GBP&gclid=CPCo_aX8n8oCFQcYwwodjlQCXg as i can see, it pushes oil to the gauge, so if that break oil will go to the cockpit right??? Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 10, 2016 Share Posted January 10, 2016 No, the volume of cold clean oil that will come out is the displacement volume of the chamber, about 3cc. There's a sealed diaphragm in the chamber. The chamber stays in the engine bay. Link to comment Share on other sites More sharing options...
jza800 Posted February 13, 2016 Author Share Posted February 13, 2016 Where is the best place to messure the water temp, the top water neck or by the thermostat??? Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 13, 2016 Share Posted February 13, 2016 Where the stock gauge and ECU temp sensors are. Link to comment Share on other sites More sharing options...
Mgrene Posted February 13, 2016 Share Posted February 13, 2016 I use DEFI. No problems so far [emoji1360] Link to comment Share on other sites More sharing options...
Kendo11 Posted February 13, 2016 Share Posted February 13, 2016 Defi here too. Faultless. Link to comment Share on other sites More sharing options...
TRD-Rob Posted February 14, 2016 Share Posted February 14, 2016 Prosports are good and have a large selection. Link to comment Share on other sites More sharing options...
Attero Posted February 14, 2016 Share Posted February 14, 2016 I was going to purchase Defi... when I win the lottery. Waiting for a second hand kit. Link to comment Share on other sites More sharing options...
jza800 Posted February 14, 2016 Author Share Posted February 14, 2016 I have looked on depo 4 in 1 gauge/ multi d/a gauges as i dont like the oil pressure sensor that are on all other gauges, the one on the depo are smaller and with a wirring attach on the sensor so belive that they are better, as the defi greddy uses them too.. Link to comment Share on other sites More sharing options...
jza800 Posted February 16, 2016 Author Share Posted February 16, 2016 no one Link to comment Share on other sites More sharing options...
