Anyone got a part No for Facelift Jap Headlights?
gordy.r
Having some confusion with my local Toyota Garage, they have several part numbers but I want to just make sure we order the right set.
Currently got pre facelift lights on my 1994 import TT, I'm guessing it's just the facelift headlights and sidelights/indicators I need to order for the conversion? 4 items in total?
Cheers in advance.
i make it -
81135 UNIT ASSY, HEADLAMP, RH
81111-1B231
81150 HEADLAMP ASSY, LH
81150-1B231
and the indicators being-
81520 LAMP ASSY, FRONT TURN SIGNAL, LH
81520-80086
81510 LAMP ASSY, FRONT TURN SIGNAL, RH
81510-80086
Cheers mate, much appreciated :thumbs:
sorry that shoudl have read-
81110 HEADLAMP ASSY, RH
81110-1B231
81150-1B231
81520-80086
81510-80086
that is for the complete package looms bulbs etc i think
Edited by ripped_fear (see edit history)
81111-1B231 UNIT ASSY, HEADLAMP, RH
81151-1B231 UNIT ASSY, HEADLAMP, LH
81510-80086 LAMP ASSY, FRONT TURN SIGNAL, RH
81520-80086 LAMP ASSY, FRONT TURN SIGNAL, LH
The LH front indicator/sidelight doesn't include the wiring harness (they plug directly into the main wiring loom on a facelift) so you will either need to fabricate a harness or buy an extra RH wiring harness (the tabs of the bulb holder will need modifying slightly to fit the LH indicator). Either way they are not plug and play, you'll need to wire up the side lights to the wires that go to the headlights on a pre-facelift, there is a guide here: http://www.mkivsupra.net/vbb/showthread.php?31633-How-To-Fit-facelift-front-indicators
This is the part number for the extra harness
81515-14390 PLUG ASSY, FRONT TURN SIGNAL LAMP
