UK vs Jap spec turbo
binfieldx
From the factory the most obvious unique visual features of the UK spec are the bonnet scoop, rear light combination, glass headlights and headlight washers but these are things that can be added, removed or modified. The only real way to tell a true UK spec is to check the VIN plate details.
Uk's are not actually better to be fair they can just handle more boost as they are made of steal , the jspecs are slighty larger and ceramic making them actually better for stock use and spool quicker, its only when you up the boost over 1.2 the uk specs out perform/ can take the boost.
