Titan Motorsports Pro Drag 3.2L Stroker Kit - Aluminum Rod
nero
Titan Motorsports Pro Drag 3.2L Aluminum Rod stroker kit is for the serious drag racer looking for max horsepower to gain that extra edge and lower their ETs. This is a race only setup, if you’re thinking about using this in your daily driver or weekend street car think again, we’ve got plenty of other setups designed for your application. This kit has been proven in some of the fastest 2JZs in the world and comes complete with everything your machine shop needs to install minus main bearings and recomended Titan Motorsports main caps.
This 90mm Stroke crankshaft, Aluminum Rod equiped stroker kit is designed for high RPM and capable of over 2,000hp of reliable dyno proven horsepower. Included in the kit is a 90mm stroke Billet Crankshaft, Oil Drive Gear, Titan Spec GRP aluminum rods, rod bearings, Titan Race Pistons, Ring Package and Coated wrist pins. If you’re looking for the ultimate track only drag race stroker kit for your 2JZ, look no further.
Available Now : TITAN PRO DRAG 3.2L ALUMINUM ROD STROKER KIT
http://www.titanmotorsports.com/2z-drag-aluminum-rod-stroker-kit.html
