brom86 Posted January 6, 2016 Share Posted January 6, 2016 Has anyone experienced the reverse gear being hesitant to change into? I can put it into reverse however can take anywhere from 3 to 10 seconds to change. Checked level and seems ok. Any suggestions on what could be or to fix? Quote Link to comment Share on other sites More sharing options...
trebor69 Posted January 6, 2016 Share Posted January 6, 2016 Girlfriend's lucida had a leak from one of the pipes (trans cooler)and the level got quite low anyway she eventually had it fixed and although the fluid is back up to level it has had this same issue ever since. I don't know if this helps you any.... Quote Link to comment Share on other sites More sharing options...
brom86 Posted January 6, 2016 Author Share Posted January 6, 2016 (edited) I'll maybe get the gearbox fluid changed over and see how that goes Edited January 6, 2016 by brom86 (see edit history) Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted January 12, 2016 Share Posted January 12, 2016 Assuming you checked the level properly (engine started and gears R, N, D, 1 selected before putting back into P/ N to check level), look at the lines themselves to make sure they have no kinks anywhere or restrictions. Quote Link to comment Share on other sites More sharing options...
David P Posted January 12, 2016 Share Posted January 12, 2016 It sounds like low fluid level from lack of maintenance. It's incredible just how many lovingly polished Supra's that have never had the dipstick looked at since they left the factory. Quote Link to comment Share on other sites More sharing options...
David P Posted January 12, 2016 Share Posted January 12, 2016 (edited) There has recently been such a spate of similar self inflictions, I have added a numbnuts check list to the Transmission Group. http://www.mkivsupra.net/vbb/group.php?groupid=57 Edited January 12, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Slam Posted January 12, 2016 Share Posted January 12, 2016 Has anyone experienced the reverse gear being hesitant to change into? I can put it into reverse however can take anywhere from 3 to 10 seconds to change. Checked level and seems ok. Any suggestions on what could be or to fix? I am having the same issue Quote Link to comment Share on other sites More sharing options...
Slam Posted January 12, 2016 Share Posted January 12, 2016 There has recently been such a spate of similar self inflictions, I have added a numbnuts check list to the Transmission Group. Think i will join the numnuts group Quote Link to comment Share on other sites More sharing options...
David P Posted January 12, 2016 Share Posted January 12, 2016 That's what it's for. numbnut. I add the answer to every auto transmission question I get asked and have Indexed them by post title, to save keep answering them again-again-again. When a new one pops up, I just add it to the list, I'm one post behind re. Throttle Position Sensor adjustment at the mo, because my Workshop Manuals are out on loan. Quote Link to comment Share on other sites More sharing options...
Slam Posted January 12, 2016 Share Posted January 12, 2016 Thanks for putting up the link. Quote Link to comment Share on other sites More sharing options...
brom86 Posted January 12, 2016 Author Share Posted January 12, 2016 I can't get it to work because am using tapa talk. Can u put a post of the thread so it will go to the top of my feed. Car is booked in at end of the month for an underseal so I'll change fluid over Quote Link to comment Share on other sites More sharing options...
Slam Posted January 12, 2016 Share Posted January 12, 2016 I too having same issue. Come on David Quote Link to comment Share on other sites More sharing options...
David P Posted January 12, 2016 Share Posted January 12, 2016 There has recently been such a spate of similar self inflictions, I have added a numbnuts check list to the Transmission Group. http://www.mkivsupra.net/vbb/group.php?groupid=57 Quote Link to comment Share on other sites More sharing options...
David P Posted January 12, 2016 Share Posted January 12, 2016 (edited) Low fluid level, 20 years old fluid or a partially blocked strainer is my best Mystic Dave prediction for this one(s). Edited January 12, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted January 14, 2016 Share Posted January 14, 2016 (edited) This guide that I have added to the Transmission Group might help? http://www.mkivsupra.net/vbb/group.php?discussionid=189&do=discuss Most faults are self inflicted by poor maintenance, electrickery dickery and throttle body tinkerings. Should your transmission fail to work properly, if you have recently tinkered with any of the above, there would be a good place to start. Check list. 1. Correct fluid level is crucially important. http://www.mkivsupra.net/vbb/group.php?discussionid=188&do=discuss 2. Check for any fault codes. http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes 3. Correct signal from odometer is vital, check for poor connections on speed converter. http://www.mkivsupra.net/vbb/showthread.php?72588-Code-42-Fix&highlight=pink+wire+mod 4. Correct setting of Throttle Position Sensor is essential. http://www.mkivsupra.net/vbb/group.php?gmid=2546&do=discuss#gmessage2546 (If you have dicked with the throttle stop, you may have a problem) 5. Speed sensor signal is imperative. (See links on 2 & 3.) Edited January 14, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted January 14, 2016 Share Posted January 14, 2016 I don't know if either of you have tinkered with the control cables on the throttle body? If you have, check that you have refitted the line feed cable onto the correct ramp and is adjusted correctly. Quote Link to comment Share on other sites More sharing options...
brom86 Posted January 14, 2016 Author Share Posted January 14, 2016 Not fiddled with anything other than myself lol Quote Link to comment Share on other sites More sharing options...
Slam Posted January 14, 2016 Share Posted January 14, 2016 Not fiddled with anything other than myself lol Nothing like being honest David likes that Quote Link to comment Share on other sites More sharing options...
Slam Posted January 14, 2016 Share Posted January 14, 2016 This guide that I have added to the Transmission Group might help? http://www.mkivsupra.net/vbb/group.php?discussionid=189&do=discuss Most faults are self inflicted by poor maintenance, electrickery $#@!ery and throttle body tinkerings. Should your transmission fail to work properly, if you have recently tinkered with any of the above, there would be a good place to start. Check list. 1. Correct fluid level is crucially important. http://www.mkivsupra.net/vbb/group.php?discussionid=188&do=discuss 2. Check for any fault codes. http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes 3. Correct signal from odometer is vital, check for poor connections on speed converter. http://www.mkivsupra.net/vbb/showthread.php?72588-Code-42-Fix&highlight=pink+wire+mod 4. Correct setting of Throttle Position Sensor is essential. http://www.mkivsupra.net/vbb/group.php?gmid=2546&do=discuss#gmessage2546 (If you have $#@!ed with the throttle stop, you may have a problem) 5. Speed sensor signal is imperative. (See links on 2 & 3.) Links dont want to work on tappy talk. Will try standard version Quote Link to comment Share on other sites More sharing options...
Delboy52 Posted January 16, 2016 Share Posted January 16, 2016 Throttle Position Sensor adjustment at the mo, because my Workshop Manuals are out on loan. I have some colourful PDF's with random pages missing for extra irritation if you miss your complete set of paper manuals? They are living the life of luxury on a cosy shelf in my garage waiting for your signal to return. Dare I say, we might actually be done with fault finding on my Supra. Quote Link to comment Share on other sites More sharing options...
David P Posted January 16, 2016 Share Posted January 16, 2016 I found pics of the pages and have posted them in the transmission Group for reference. You might? Quote Link to comment Share on other sites More sharing options...
