SupraStar 3000 Posted January 5, 2016 Share Posted January 5, 2016 I know that about 5 seconds after I post this thread the next reply will take the piss,... ... but I'm genuinely baffled about this mystery and would love to know what is going on. We moved into our new build house about 4/5yrs ago. The house was newly carpeted in every room except the kitchen where we had laminate floor. Everything has been fine with the carpet. The material seems to standing up to general wear and tear pretty good. Gets vacuumed every week and the occasional spill removed with carpet shampoo. About 3 months ago I noticed a strange mark on the carpet near to a wall. The stain pattern is very uniformed and defined. 3 parallel lines (like sergeant stripes). Dark in colour,... almost oily in texture. Could not removed the stain with any amount of carpet cleaner or elbow grease. Then more and more started appearing. Sometimes in different orientations, but always 3 parallel lines together. Now they've appeared in every room in the house and in areas that nobody can possiblly get to,... like behind the TV and under the Christmas tree. Mostly these marks accumulate near the edges of rooms, beside skirting boards, under radiators and besides the bed. We never wear shoes indoors, so that rules that one out. A guy at work told me of a similar situation (think he'd seen this on tv, rather experience it first hand) where some strange patterns had appeared on walls in a house. The pattens kinda resembled large symmetrical snow flakes but in a dark colour. After much consideration, a possible (and plausible) reason behind this was due to old nails being hit into the plaster walls with a hammer (presumably during construction). The act of hitting the nails hard with a hammer, rather than using a screw, coursed the nail to magnetize. Then as time passed small amounts of iron/metal fragments in the atmosphere were drawn towards the magnetized nails leaving these strange patterns on the outside of the wall. Now I'm not saying this is what I have in my house,... probably not even similar,.... but I do wonder if there is an scientific answer to what is going on? Quote Link to comment Share on other sites More sharing options...
Westcoaster Posted January 5, 2016 Share Posted January 5, 2016 The parallel lines will have been caused by a carpet stretcher when the carpets were originally fitted - not sure what's causing the staining though. A professional cleaner may know how to clean the stain. EDIT Possibly known as draught marks! http://www.cleanercarpets.org/draughtmark.html Quote Link to comment Share on other sites More sharing options...
mellonman Posted January 5, 2016 Share Posted January 5, 2016 I will hold back the dungeon comments , but it sounds like damp / mold to me mate Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 5, 2016 Author Share Posted January 5, 2016 Just had a look online at carpet stretchers. The pattern certainly seems to fit in size and proportion - Think you might be onto something with that idea. Kinda makes sense,.... but why have the marks suddenly gone darker. Nothing was visible before?? Cheers for idea. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 5, 2016 Author Share Posted January 5, 2016 I will hold back the dungeon comments , but it sounds like damp / mold to me mate To be honest, Even I'd struggle to produce the quantities of jizz stains we're talking about here. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 5, 2016 Share Posted January 5, 2016 Just had a look online at carpet stretchers. The pattern certainly seems to fit in size and proportion - Think you might be onto something with that idea. Kinda makes sense,.... but why have the marks suddenly gone darker. Nothing was visible before?? Cheers for idea. Wear and tear. As the carpet is succumbing to the stretch the fibres are rotating and showing up the cleaner surface (original colour). Try back combing the carpet to see the colour under the pile to see if it matches. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 5, 2016 Share Posted January 5, 2016 Have you tried lifting the carpet at the line location? are there by any chance vents underneath? Quote Link to comment Share on other sites More sharing options...
ashloys Posted January 6, 2016 Share Posted January 6, 2016 Any pictures of the carpet? Quote Link to comment Share on other sites More sharing options...
cered Posted January 6, 2016 Share Posted January 6, 2016 The patterns are probably caused the backing/underside of it... What's making the patterns appear si water ingress or mold. Best bet is to pull the carpet up and have a look. Is your home in a floood zone or on pretty low ground? Quote Link to comment Share on other sites More sharing options...
Thorin Posted January 6, 2016 Share Posted January 6, 2016 Aliens. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 6, 2016 Share Posted January 6, 2016 Carpet stretcher wouldn't make marks like that. In fact they shouldn't make any marks not that I've seen within 10 years of fitting. Gotta be the backing or something underneath, can you not get a picture? Quote Link to comment Share on other sites More sharing options...
Burna Posted January 6, 2016 Share Posted January 6, 2016 You need new carpet, Nizam's your man for this Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted January 6, 2016 Share Posted January 6, 2016 I know that about 5 seconds after I post this thread the next reply will take the piss,... ... but I wouldn't usually read a carpet thread Ed but since your name was on it mate!!! Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 6, 2016 Author Share Posted January 6, 2016 Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 6, 2016 Author Share Posted January 6, 2016 I wouldn't usually read a carpet thread Ed but since your name was on it mate!!! I've mentioned carpet and still waiting for someone to say "Munchin". This forum is going down hill. Hiya mate. Happy new year to you buddy. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 6, 2016 Author Share Posted January 6, 2016 You need new carpet, Nizam's your man for this Is he still on the forum?? I wonder if he gets rug stains the same as me. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 6, 2016 Author Share Posted January 6, 2016 Have you tried lifting the carpet at the line location? are there by any chance vents underneath? Under the carpet the liner (or underlay) is perfect. Looks fine. No mould or dampness. No vents too. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 7, 2016 Share Posted January 7, 2016 Well I take back my previous statement as that definitely looks like a stretcher. How? I don't know. Maybe he's covered the teeth in wd40 for some reason. Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted January 7, 2016 Share Posted January 7, 2016 I've mentioned carpet and still waiting for someone to say "Munchin". This forum is going down hill. Hiya mate. Happy new year to you buddy. You too, great to be in contact again. This thread is a bit like the crop circles puzzle of the carpet world. I'm now gripped' Ed mate :-) Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted January 7, 2016 Share Posted January 7, 2016 This thread just makes things too easy................. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 8, 2016 Author Share Posted January 8, 2016 going to get some cleaner and scrub the hell out of the carpet this weekend. See what a difference that will make. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 8, 2016 Author Share Posted January 8, 2016 This thread just makes things too easy................. .... don't hold back G. I know what can happen if you go without innuendo for one day. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted January 8, 2016 Share Posted January 8, 2016 going to get some cleaner and scrub the hell out of the carpet this weekend. See what a difference that will make. Are you referring to your wife? Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 8, 2016 Author Share Posted January 8, 2016 Are you referring to your wife? Don't make me open this tin of 'whoop ass' on you Graham. I say whoop ass,.... but its really just a brown shade of dulux emulsion. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted January 8, 2016 Share Posted January 8, 2016 Don't make me open this tin of 'whoop ass' on you Graham. I say whoop ass,.... but its really just a brown shade of dulux emulsion. Maybe this is what you've dropped on the carpet? Whoop ass is notoriously known for being a bitch to get out. Quote Link to comment Share on other sites More sharing options...
