water bypass kit
Jellybean
Any logic in this ??
http://www.night-pager.net/cn6/pg35.html
The water bypass kit ...
From easily heater hose out the heat of the cooling water reservoir is in the radiator upper hose to stabilize the water temperature by bypassing the cooling water is cooling water circulation rate and to reduce the hydraulic resistance parts. The rear cylinder temperature at which heat is likely to accumulate by the bypass function is stable, to prevent heat sagging and overheating of the engine while controlling the water temperature rise. When used in conjunction the cooling thermostat, it is the part where there is a higher effect.
It did give me a chuckle
I am not too sure but from what I understand it connects the front rad pipe to the rear of the block so instead of waiting for the water to circulate through the block to get the rear , the coolant bypasses and has a direct feed to the rear , warms up quicker
