add heywood Posted January 5, 2016 Share Posted January 5, 2016 And can you get a plug adapter to convert this to a denso 2 pin injevtor plug? Failing that anyone know where I can source a male denso injector plug wig pigtail so I can make my own. Cheers Quote Link to comment Share on other sites More sharing options...
Dr Moz Posted January 5, 2016 Share Posted January 5, 2016 Looks like a Jetronic connector to me. I could be wrong though. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 5, 2016 Share Posted January 5, 2016 (edited) Bosch Junior Timer style. The shells and contacts are cheap, the correct crimp tool, well, OUCH!! You can get by with some cheaper crimp tools, but the proper one makes it all so easy. If going to the stock engine loom these may make life easy: http://www.ebay.co.uk/itm/Jetronic-EV1-Female-to-Toyota-Male-Injector-Plug-Adaptors-Wired-/111677357843?hash=item1a007d3f13:g:BtIAAOSwl8NVXx4A Edited January 5, 2016 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted January 5, 2016 Share Posted January 5, 2016 Indeed, Junior Power Timer 2 connector. Be aware there are a couple of different pin types and shells. The shorties tend to not allow the seal to sit inside the shell. Some come with small crimp diameter and others large. If you are crimping them on a supra loom you want the large diameter ones. There are also round and c shaped bung tags also not all shells have injector scallops. There are also cheap nissan style ones which a PITA to get off again. I tend to use 3wayComp for these as they are good quality, scalloped, easy release and are a complete kit with no gotha's. http://www.ebay.co.uk/itm/Genuine-AMP-TYCO-2-Way-Pin-Junior-Power-Timer-Terminals-Boot-and-Cable-Seals-/141054539749?hash=item20d78177e5:g:-rMAAOxyrrpTe0MB Quote Link to comment Share on other sites More sharing options...
add heywood Posted January 5, 2016 Author Share Posted January 5, 2016 It's actually going on my fd3s rx7... Chris, would the ones you linked to still work on a stock fd loom (denso male injector plug)? Been difficult to track down... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 5, 2016 Share Posted January 5, 2016 Err, probably, I think I have used FD injectors in Supras and they took the stock loom plugs. But don't berate me if my memory is wrong... Quote Link to comment Share on other sites More sharing options...
add heywood Posted January 5, 2016 Author Share Posted January 5, 2016 Ha ha, its on your shoulders On a side note the injectors will be with you by Friday/Saturday as per my email over xmas. I'll send you tracking details etc when I have them tomorrow Quote Link to comment Share on other sites More sharing options...
