4 abs hubs from a tt
Ross McG
You also need the rear ABS drive shafts too as the teeth for the sensor are built into the shaft not the hub. Also need to know which size Diff you have (small or large case) as the drive shafts are different. Keron may have a set!?
You can get away with 2, one front and one rear. If your limited for inputs on the syvecs thats the solution thats being put on some cars.
Personally I wanted the calculations to be based on average front and average rear. Therefore I swapped all 4 and used the digital convertors for the front inputs to the ECU.
