supra_24 Posted December 29, 2015 Share Posted December 29, 2015 Hi guys, recently had a single turbo conversion done on the supra and a syvecs ecu fitted and mapped on tesco 99 super unleaded/V-power. Car was mapped at Litchfields Dyno with the help of I believe Ryan from syvecs. I had a Garage Whifbitz T4 twin wastegate twin scroll single turbo kit for the Supra fitted and setup with Borg Warner S300 SXE turbo. http://www.garagewhifbitz.co.uk/garage-whifbitz-2107.html Silent hi power hks exhaust. Full decat Syvecs S6 ecu Brand new 450 fuel pump. Car only run on V-power and tesco 99 super unleaded. New uprated spark plugs etc. 2 things I have noticed that I just wanted to run by you guys for peace of mind is the following: 1) With the mapped syvecs ecu on cold startup, the ecu takes a little longer to intially crank the engine, compared to original ecu. Is this just the behaviour of syvecs to crank around 4 times after turning the key and then starting the engine? 2) I have also noticed that there was a bit of black dry soot around the exhaust and covering an area of ground near to the exhaust. The car recently had sat for about 4 days during christmas period before being started up again. Is the soot build up normal or does anyone else experience this? Someone did mention carbon build up and condensation in exhaust, especially if it hadnt beenn run for a long journey in a while. The car has been mapped at Litchfields via whifbitz and syvecs and was double checked over to make sure everything was spot on. Car runs fine and drives/idles smooth. No smoke of any kind from what I can see. Any help and advise on this as always is appreciated. Cheers. Quote Link to comment Share on other sites More sharing options...
Style Posted December 29, 2015 Share Posted December 29, 2015 Ever since I got my AEM installed my car has taken a lot more cranks to get the car started. I always thought it was just down to the map. It is a bit dodgy though. Almost catches a few times before eventually firing up. That how yours sounds? Quote Link to comment Share on other sites More sharing options...
supra_24 Posted December 29, 2015 Author Share Posted December 29, 2015 Yeah cranks more than it did with the standard ecu. Sounds like it cranks 3 to 4 times and then fires up. So like crank, crank, crank, crank, fire. Runs perfectly after initial crank startup. You wouldn't have any ideas on the black soot either mate would you? Been told its carbon and moisture build up in exhaust? Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted December 29, 2015 Share Posted December 29, 2015 I believe the Syvecs does it for safety reasons, I think it because it checks the engine has the correct oil pressure and everything is okay before firing. We have a Syvecs fitted and it does the same. Quote Link to comment Share on other sites More sharing options...
Hemanhead Posted December 29, 2015 Share Posted December 29, 2015 Yep mine is the same, and yes the exhaust is sooty and i don't find that atall surprising given how much fuel it throws in. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted December 29, 2015 Share Posted December 29, 2015 My syvecs does the same, i usually wait a little bit to let the fuel pump prime first, then it takes a couple of cranks and fires up Quote Link to comment Share on other sites More sharing options...
chazuk Posted December 29, 2015 Share Posted December 29, 2015 The extra crank to fire up is so it builds more oil pressure before starting. The soot mine did exactly the same as well I parked it in front of the garage door once and there was a football sized black splatter patch afterwards Quote Link to comment Share on other sites More sharing options...
FOSTA Posted December 29, 2015 Share Posted December 29, 2015 Yep same here too! Quote Link to comment Share on other sites More sharing options...
MattP Posted December 30, 2015 Share Posted December 30, 2015 The additional cranking is for oil pressure reasons yes it's all good Quote Link to comment Share on other sites More sharing options...
Mike B Posted January 1, 2016 Share Posted January 1, 2016 I believe the Syvecs does it for safety reasons, I think it because it checks the engine has the correct oil pressure and everything is okay before firing. We have a Syvecs fitted and it does the same. I asked Ryan about the same thing my syvecs and there is a code in there where you set the number of cranks before the engine is allowed to fire - Ryan did say that it's better to crank the oil through the engine before firing - sounds sensible :-) Quote Link to comment Share on other sites More sharing options...
