ardasaliah Posted September 11, 2005 Share Posted September 11, 2005 I know its not mkiv but had no luck there so far- hope its OK http://www.mkivsupra.net/vbb/showthread.php?t=46684 cheers Link to comment Share on other sites More sharing options...
TrickTT Posted September 11, 2005 Share Posted September 11, 2005 possible some play in the engine mounting or gearbox linkage. Put it i 4th with the engine off, clutch out, to lock the gearbox, then try to move the gearstick. if it still moves, its the linkage, if not its the engine mount. Fairly common on FWD cars. Link to comment Share on other sites More sharing options...
ardasaliah Posted September 11, 2005 Author Share Posted September 11, 2005 Thanks for the advice but. The gearstick just moves out of gear when I move it. When driving in forth and I apply the power-the movement is very small-just 1/2cm if that. When I tried your suggestion you can't really tell because it just moves out of gear nutral Cheers Link to comment Share on other sites More sharing options...
