gurteen0 Posted December 25, 2015 Share Posted December 25, 2015 Merry Xmas all just a question I hope some one can help me on or send me in the right way my supra tt has blue smoke on start up been told that stem seals need replacing has anyone got an idea of price or who is best to take it to as wanna get done asap as it is burning a lot of oil any help would be great Quote Link to comment Share on other sites More sharing options...
Nic Posted December 25, 2015 Share Posted December 25, 2015 How much oil is it using? http://www.mkivsupra.net/vbb/showthread.php?319358-Valve-stem-seals Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 25, 2015 Author Share Posted December 25, 2015 130 miles with a bit of hard driving is taking it down to half way between full and low only smoke for a few seconds on cold start than almost fine other than a tiny bit in traffic on pull off other than that it drives perfect Quote Link to comment Share on other sites More sharing options...
Scooter Posted December 25, 2015 Share Posted December 25, 2015 Might want to check the turbo seals as I don't think the seals will cause that high a rate of oil loss... Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 25, 2015 Author Share Posted December 25, 2015 Not getting smoke on boost I don't think? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 25, 2015 Share Posted December 25, 2015 You get smoke on hot idle with shot turbo seals. If both those seals failed it still wouldnt account for that much oil loss. Its what, a litre of oil in 130 miles? You'd notice the smoke for sure! Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 25, 2015 Author Share Posted December 25, 2015 Stem seals? Quote Link to comment Share on other sites More sharing options...
MKIV-Supra Posted December 25, 2015 Share Posted December 25, 2015 Check the compression could be the Piston rings too. 0.5l - 1l is too much for Valve stem Seals. I think shot turbo or Piston rings. Quote Link to comment Share on other sites More sharing options...
rider Posted December 26, 2015 Share Posted December 26, 2015 130 miles with a bit of hard driving is taking it down to half way between full and low only smoke for a few seconds on cold start than almost fine other than a tiny bit in traffic on pull off other than that it drives perfect That's way too much oil for stem seals. Likely Turbo seal or broken ring. Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 26, 2015 Author Share Posted December 26, 2015 Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 26, 2015 Author Share Posted December 26, 2015 Here are a few pics from today checking pipes out and taking plugs out the plugs are dry but did have oil sitting on top of plugs like a pipe was leaking on top confused Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 26, 2015 Share Posted December 26, 2015 The oil in the pipework is perfectly acceptable and normal, and is from the breather system. Oil in the cylinder head well is probably from a combination of leaky cam cover gaskets and messy oil top ups. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 26, 2015 Share Posted December 26, 2015 It could *VERY* well be stem seals and with new turbos at circa £1300 plus VAT each, and about another £1000 to fit and supply gaskets, oil, filter etcetera I suggest you start by changing the stem seals! Bear in mind the valve guides may well be knackered too, these are old engines. Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 26, 2015 Author Share Posted December 26, 2015 Would the colour of plugs give some kind of answer to it Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 26, 2015 Share Posted December 26, 2015 Maybe... Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 26, 2015 Author Share Posted December 26, 2015 I will pull them out and have a look will up load a pic soon as this is doing my head in only had the car a month and spent money on making it look nice only to have this issue Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 26, 2015 Author Share Posted December 26, 2015 Thanks guys for the help so far Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 26, 2015 Share Posted December 26, 2015 Thats the problem, forget making it look nice, make it mechanically perfect first. They are old cars, they will need things doing. Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 27, 2015 Author Share Posted December 27, 2015 I took the old owners word that all was good so thought I could get on with styling but oh well she been perfect in the end lol Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 27, 2015 Author Share Posted December 27, 2015 Evening all done a compression test today here are the results 1=175 2=175 3=175 4=175 5=170 6=142 Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 28, 2015 Share Posted December 28, 2015 Oh dear! I'd suggest getting a leak down test done sooner rather than later, as that will be more accurate in finding out what's going on with cylinder 6 Quote Link to comment Share on other sites More sharing options...
rider Posted December 28, 2015 Share Posted December 28, 2015 Oh dear! I'd suggest getting a leak down test done sooner rather than later You can buy kits readily to run this test if you also have an air compressor to hand. There is a good write up available on how to diagnose if you do get pressure leakage, http://www.allpar.com/fix/leakdown-test.html Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted December 28, 2015 Author Share Posted December 28, 2015 Nice one mate will look into it Quote Link to comment Share on other sites More sharing options...
