Mark brooks Posted December 22, 2015 Share Posted December 22, 2015 I'm looking at running 18x9.5 front 18x11 rear Would these fit on a stock body and if so what offsets would I need? And recommended tyre size Quote Link to comment Share on other sites More sharing options...
Guest paok Posted December 23, 2015 Share Posted December 23, 2015 Hello. my car has 265x30 in 9.5x19 front and 315x25 rear in 11.5x19 Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted December 23, 2015 Share Posted December 23, 2015 Nice, any pics poak Quote Link to comment Share on other sites More sharing options...
Clausz Posted December 23, 2015 Share Posted December 23, 2015 I have an stock 17"x11" wheel on rear, without any modifications to the fender. 315 wide tyres. Quote Link to comment Share on other sites More sharing options...
Mark brooks Posted December 23, 2015 Author Share Posted December 23, 2015 Ok what offsets are you running? Quote Link to comment Share on other sites More sharing options...
jazz1 Posted December 23, 2015 Share Posted December 23, 2015 I'm running 19x12 on my rears. Quote Link to comment Share on other sites More sharing options...
Mark brooks Posted December 25, 2015 Author Share Posted December 25, 2015 Still wanting advice on offsets. I'm looking at xxz 531 in 18x9.5 front and 18x11 rear if anyone has these could they post a picture please Quote Link to comment Share on other sites More sharing options...
supra matt Posted December 25, 2015 Share Posted December 25, 2015 On the rear you will be looking at around a et45 and front around a 32 I believe Quote Link to comment Share on other sites More sharing options...
supra matt Posted December 25, 2015 Share Posted December 25, 2015 http://www.mkivsupra.net/vbb/showthread.php?t=211133 Quote Link to comment Share on other sites More sharing options...
Nic Posted December 25, 2015 Share Posted December 25, 2015 (edited) And recommended tyre size http://www.brick-yard.co.uk/forum/tyre-size-for-rim-width_topic60146.html Stock tyre sizes 235/45R17 255/45R17 You should aim to keep the circumference of the tyres close to stock, use this tyre calculator to compare against the stock tyre sizes to work out the required aspect ratio/profile, this will vary depending on the width of tyre you decide on (the aspect ratio/profile is a % of the wheel width). If you know your current wheel widths and offsets you can also use this calculator to work out the wheel width and offset you want. http://www.willtheyfit.com If you have the larger Supra brakes fitted you'll need to make whatever wheels you go with will clear them. Edited December 25, 2015 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Clausz Posted December 29, 2015 Share Posted December 29, 2015 Mine is a stock 17" which is think is ET37, and then I have mounted a 20mm spacer on them. Quote Link to comment Share on other sites More sharing options...
