Biggest wheels on stock body
Mark brooks
And recommended tyre size
http://www.brick-yard.co.uk/forum/tyre-size-for-rim-width_topic60146.html
Stock tyre sizes
235/45R17
255/45R17
You should aim to keep the circumference of the tyres close to stock, use this tyre calculator to compare against the stock tyre sizes to work out the required aspect ratio/profile, this will vary depending on the width of tyre you decide on (the aspect ratio/profile is a % of the wheel width).
If you know your current wheel widths and offsets you can also use this calculator to work out the wheel width and offset you want.
http://www.willtheyfit.com
If you have the larger Supra brakes fitted you'll need to make whatever wheels you go with will clear them.
