fullthrottle Posted December 22, 2015 Share Posted December 22, 2015 Ok I am about to order a new set of wheels and because of my brake calipers I need to run 19". So I have two options that I like they will be in gloss black finish. They are HRE P107 Or CCW sp2k Front 19x10 Rear 19x11.5 I am not sure on offset yet but my question is does anyone know what the quality is like on the hre wheels as I have read a lot of people complain about build quality and damage is this true ? I am leaning more towards purchasing these as I can purchase them in the UK rather order ccw from the states Quote Link to comment Share on other sites More sharing options...
Style Posted December 22, 2015 Share Posted December 22, 2015 Those width's in 19" will not fit stock arches I don't think. I have 18" CCW's in the same widths and that's pretty much as big as you can go for stock body wheels, 19's will scrub the inner and outer arch I'd imagine. Have only ever heard good stories about HRE though to answer your question Quote Link to comment Share on other sites More sharing options...
fullthrottle Posted December 22, 2015 Author Share Posted December 22, 2015 Those width's in 19" will not fit stock arches I don't think. I have 18" CCW's in the same widths and that's pretty much as big as you can go for stock body wheels, 19's will scrub the inner and outer arch I'd imagine. Have only ever heard good stories about HRE though to answer your question They will mate you just need to roll or cut the rear arches and I think have coil overs fitted for clearance on the inside. All this I have already done as I am using 20" with 295 on the rear Quote Link to comment Share on other sites More sharing options...
listy Posted December 22, 2015 Share Posted December 22, 2015 Surely regardless of brakes you could get a set of 18s that would fit? It's just the design and offset that should matter. I'm sure the whifbitz track car had humongous brakes and ran 18s. Which brakes do you have? Quote Link to comment Share on other sites More sharing options...
