mrboomberang Posted December 20, 2015 Share Posted December 20, 2015 Does anyone know if there are any difference between the auto pre facelift radiator and auto tiptronic facelift radiator. ? Quote Link to comment Share on other sites More sharing options...
Nic Posted December 20, 2015 Share Posted December 20, 2015 The part number on the EPC is the same for all 2JZ-GTE autos. Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted December 20, 2015 Author Share Posted December 20, 2015 The part number on the EPC is the same for all 2JZ-GTE autos. http://i64.tinypic.com/2zs5ppi.jpg Cheers nic just what I was looking for Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 20, 2015 Share Posted December 20, 2015 In reality there are different fan shroud pick up mounts on the end tanks. Safest way is to send someone a good photo of the engine side of the rad, with the shroud off, out of the car. Someone (I for example...) can then be sure to send you the right one! There seems to be little rhyme or reason in when the mounts changed. Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted December 23, 2015 Author Share Posted December 23, 2015 In reality there are different fan shroud pick up mounts on the end tanks. Safest way is to send someone a good photo of the engine side of the rad, with the shroud off, out of the car. Someone (I for example...) can then be sure to send you the right one! There seems to be little rhyme or reason in when the mounts changed. Cheers for that info Chris I will check Quote Link to comment Share on other sites More sharing options...
