foggy147 Posted December 14, 2015 Share Posted December 14, 2015 Hoping someone could help. I am trying to adjust the temp of the water on the boiler and not sure if the settings are right. If you look at the attached are the dials in the correct position to have water temp of about 60 degrees? Any help would be appreciated! Link to comment Share on other sites More sharing options...
jsnlvxr Posted December 14, 2015 Share Posted December 14, 2015 The big white dial is the immersion heater stat.the top right brass dial is what controls the hot water temperature made by the boiler.which looks like it's set to minimum.i would set that to about 3.5. Link to comment Share on other sites More sharing options...
foggy147 Posted December 14, 2015 Author Share Posted December 14, 2015 OK thanks will try that. Is the immersion state set correctly? Link to comment Share on other sites More sharing options...
jsnlvxr Posted December 14, 2015 Share Posted December 14, 2015 It's not far out. Maybe a tad high but nothing to worry about Link to comment Share on other sites More sharing options...
