Dan H Posted December 13, 2015 Share Posted December 13, 2015 Hi guys I'm taking my Supra into the garage this Friday coming to have the larger Supra brakes fitted (directly replacing the smaller stock ones) and I've been supplied with: 4 pot front calipers (x2), 2 pot rear calipers (x2), Shim kit, Brake discs and pads (x4). and rear covers for the disc brakes(x2). Is there anything else I would need to get hold of before hand in order to do the conversion ? Dan Link to comment Share on other sites More sharing options...
David P Posted December 13, 2015 Share Posted December 13, 2015 You are missing the front back plates, yet it'll live without them. Maybe a good idea to change the flexi brake hoses whilst you're at it? Link to comment Share on other sites More sharing options...
Dnk Posted December 13, 2015 Share Posted December 13, 2015 Do a full brake fluid change while your at it Link to comment Share on other sites More sharing options...
Nic Posted December 13, 2015 Share Posted December 13, 2015 You will also need 1 x 04947-14010 FITTING KIT, DISC BRAKE, FRONT 1 x 04948-14010 FITTING KIT, DISC BRAKE, REAR Link to comment Share on other sites More sharing options...
Dan H Posted December 13, 2015 Author Share Posted December 13, 2015 Ah thanks Nic this was the one thing the dealership didn't supply me with. Will the fitting kit part clips from the existing smaller brakes not fit over the larger ones ? Link to comment Share on other sites More sharing options...
Nic Posted December 13, 2015 Share Posted December 13, 2015 (edited) Ah thanks Nic this was the one thing the dealership didn't supply me with. Will the fitting kit part clips from the existing smaller brakes not fit over the larger ones ? I'm almost certain the fitting kits for the pads are not interchangeable, hopefully someone else can confirm. Edited December 13, 2015 by Nic (see edit history) Link to comment Share on other sites More sharing options...
trebor69 Posted December 13, 2015 Share Posted December 13, 2015 Can't for the life of me remember if the handbrake works on shoes and if they are they same. Link to comment Share on other sites More sharing options...
Chris88 Posted December 13, 2015 Share Posted December 13, 2015 Fitting kit is not the same from J spec to UK spec (completely different) but the handbrake arrangement is exactly the same. Link to comment Share on other sites More sharing options...
David P Posted December 13, 2015 Share Posted December 13, 2015 Looks like the correct answer would have been, look at the Workshop Manual. The bolts may be different too? Link to comment Share on other sites More sharing options...
alxns7 Posted December 13, 2015 Share Posted December 13, 2015 (edited) I rebuilt my calipers recently and did not see those fitting kit parts.. Can someone tell me what this is exactly? EDIT: after checking, those contain the front pad spacers as well as the anti-rattle springs Edited December 13, 2015 by alxns7 (see edit history) Link to comment Share on other sites More sharing options...
