Guest suprageek Posted December 12, 2015 Share Posted December 12, 2015 Preferably like the ones in the pic thanks [ATTACH]207429[/ATTACH] Link to comment Share on other sites More sharing options...
SupraP-Z Posted December 14, 2015 Share Posted December 14, 2015 Double post Link to comment Share on other sites More sharing options...
SupraP-Z Posted December 14, 2015 Share Posted December 14, 2015 Ebay have got some decent ones with the same spec as other brands - quality isnt bad at all for what you pay. I bought some from super GT, 25 mm spacers - look exactly like the ones in your pic. http://www.ebay.co.uk/itm/Super-GT-Hubcentric-Bolt-On-Wheel-Spacer-5x114-60-1-25mm-M12x1-5-Toyota-Lexus-/191450247216?hash=item2c9352f030 Not sure if they do 15/20mm, may be worth taking a look. They were a perfect fit, had to use spigot rings to mount the rims onto the spacer - but the spacer is hubcentric itself Link to comment Share on other sites More sharing options...
Guest suprageek Posted December 14, 2015 Share Posted December 14, 2015 Double post Double post? Link to comment Share on other sites More sharing options...
Guest suprageek Posted December 14, 2015 Share Posted December 14, 2015 Ebay have got some decent ones with the same spec as other brands - quality isnt bad at all for what you pay. I bought some from super GT, 25 mm spacers - look exactly like the ones in your pic. http://www.ebay.co.uk/itm/Super-GT-Hubcentric-Bolt-On-Wheel-Spacer-5x114-60-1-25mm-M12x1-5-Toyota-Lexus-/191450247216?hash=item2c9352f030 Not sure if they do 15/20mm, may be worth taking a look. They were a perfect fit, had to use spigot rings to mount the rims onto the spacer - but the spacer is hubcentric itself Yes got these ordered last night bud in 15mm width, got spigot rings too, thanks for your reply Link to comment Share on other sites More sharing options...
SupraP-Z Posted December 14, 2015 Share Posted December 14, 2015 Sorry, i double posted lol. If you are using stock studs, you will need to cut/grind them down. I had to grind off a few mm on all of my studs as im 25mm spaced all round. Alternatively just get shorter studs, spent ages doing mine with a dremel Link to comment Share on other sites More sharing options...
Guest suprageek Posted December 14, 2015 Share Posted December 14, 2015 Sorry, i double posted lol. If you are using stock studs, you will need to cut/grind them down. I had to grind off a few mm on all of my studs as im 25mm spaced all round. Alternatively just get shorter studs, spent ages doing mine with a dremel My wheels have holes in the back of the face for the stud to fit in so no need for cutting Link to comment Share on other sites More sharing options...
SupraP-Z Posted December 15, 2015 Share Posted December 15, 2015 Lucky! pics of the wheels please Link to comment Share on other sites More sharing options...
