Correct bulb not fitting into headlights
CASHEYE
I bought some new Bosch bulbs for my headlights but the bulbs for the dipped beam won't fit. The HB3s for the high beam fit perfectly and they also fit into the dipped socket. I can see the diameter of the HB4s are slightly bigger than the HB3s so I took the plastic ring off the light housing to check and the HB4 is just too fat to fit in the hole.
any suggestions?
