Central Heating Help
Soopra
To cut a long story short the valve on our water/heating system is stuck open on both heating and water and as a result we either have both on full blast or neither...
It's just a white square box...
Is there anything I can do to switch the heating off? I've set the thermostat at zero and turned the heating off on the programmer...
Help before I melt please...
It's the valve that switches between heating and water that's failed. It's stuck open on both.
I've solved the problem by switching the whole system off.
We'll have to turn it on when we want hot water.
We have TRV's on all the radiators except the lounge which has so valves at all (something I will be mentioning when they come out to fix the valve)
