Which power steering fluid?
adam1983
I have looked at the faq section which recommends a flush will take 4 litres of dexron 3 but elsewhere on the forum it states dexron 2.
Which one should I use?
Also could anyone also confirm if it is 4 litres required to flush the ps fluid.
Wanted to make sure before putting an order in.
Cheers
Thanks for the info guys. I did think 4 litres sounded like a lot.
I will be cleaning out the reservoir too whilst I'm at it and was told I need to replace a rubber o ring whilst it's off. Does anyone happen to know what the part number for this would be. It's for a tt just in case they are different [emoji3]
