Guest AlexTC Posted December 7, 2015 Share Posted December 7, 2015 Guys just done my compression test today just to check my BG service and engine treatment.... Car running perfectly but Cylinder number 6 is only 100 psi on test and the other ones are 180-190psi... Any advice or help? Thank you Quote Link to comment Share on other sites More sharing options...
FOSTA Posted December 7, 2015 Share Posted December 7, 2015 Check again just to make sure. Could be rings or valves not sealing 100%. Quote Link to comment Share on other sites More sharing options...
Guest AlexTC Posted December 7, 2015 Share Posted December 7, 2015 doule checked them all.... But im thinking that i always done n6 last.... can it be just battery getting low? Oh and does throtle body supose to be open? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 7, 2015 Share Posted December 7, 2015 Throttle body is meant to be open. Do a wet compression check (google it) Quote Link to comment Share on other sites More sharing options...
HarleyFDMD Posted December 7, 2015 Share Posted December 7, 2015 Drop a tea spoon of oil into no.6 cylinder and then do the compression test again. If your result is better than 100psi this time it's quite possible your piston rings have perished. If the result is still around 100psi then I'd be looking at valve seats Quote Link to comment Share on other sites More sharing options...
Guest AlexTC Posted December 7, 2015 Share Posted December 7, 2015 Yes thats what im doing tomorrow. But it stood for a while... but anyway we will see Quote Link to comment Share on other sites More sharing options...
Guest AlexTC Posted December 7, 2015 Share Posted December 7, 2015 Thank you very much! will try that as well All the rest is on 190 and 180 so i think its quiet good. and there is no misfire at all... Quote Link to comment Share on other sites More sharing options...
Nic Posted December 7, 2015 Share Posted December 7, 2015 See Compresion Inspection instructions here: http://www.mkivsupra.net/vbb/content.php?65-Engine-Mechanical-(2JZ-GE) Quote Link to comment Share on other sites More sharing options...
Guest AlexTC Posted February 8, 2016 Share Posted February 8, 2016 Sorry for late reply.... Done my special system treatment and after 200 miles it went from 100 psi to 160 Quote Link to comment Share on other sites More sharing options...
MattP Posted February 8, 2016 Share Posted February 8, 2016 Sorry for late reply.... Done my special system treatment and after 200 miles it went from 100 psi to 160 Bit of Sawdust Quote Link to comment Share on other sites More sharing options...
