Piran Posted April 4, 2003 Share Posted April 4, 2003 I have 2 things I need to do to my Supra in the next few weeks ! 1) I found out why I was going through so many rear tyres ! my springs at the back are completely knackered ! so I'm getting a new set of shocks and springs (all round). Is there anything I need to be aware of or anything else that might need replacing - as the bushes etc. at the back will have been providing the only suspension ! 2) It looks like I have a faulty Lambda sensor and so will need to replace it however looking at the EPC there are 2 listed : 1 Oxygen sensor : 89465-19595 2 Oxygen sensor : 89465-19605 what is the difference between these and would a UK spec sensor be ok on a J spec car ? thanks Link to comment Share on other sites More sharing options...
Digsy Posted April 4, 2003 Share Posted April 4, 2003 If you look closely at EPC you will see the model year / month that the parts were meant to be fitted to. That should give you an indication of which part is suitable for your car. Link to comment Share on other sites More sharing options...
Steve W Posted April 4, 2003 Share Posted April 4, 2003 Aren't there 2 Lambda Sensors on the UK ? [and 1, plus the temp' sensor on the Jap' ?] Are they the SAME part number, or different ? Link to comment Share on other sites More sharing options...
