supradibbs Posted September 10, 2005 Share Posted September 10, 2005 right fitting the single kit which of the two gauges would you guy recomend egt or wideband?? thats all thank you Link to comment Share on other sites More sharing options...
JohnK Posted September 10, 2005 Share Posted September 10, 2005 Wideband is most important, EGT's should be around 100c lower than the stock setup. I run both though. Link to comment Share on other sites More sharing options...
b_have Posted September 10, 2005 Share Posted September 10, 2005 Ditto, Wideband is a MUST. Link to comment Share on other sites More sharing options...
supradibbs Posted September 10, 2005 Author Share Posted September 10, 2005 ok so egt not really that important then??? Link to comment Share on other sites More sharing options...
bedlam Posted September 10, 2005 Share Posted September 10, 2005 WB as well, EGT like has been said will be lower after you fit the single,but be a devil and fit both . Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 10, 2005 Share Posted September 10, 2005 Both... Link to comment Share on other sites More sharing options...
TLicense Posted September 10, 2005 Share Posted September 10, 2005 Both... Agreed. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 11, 2005 Share Posted September 11, 2005 Wideband is an absolute must, and a good one at that. EGT is nice, but only useful if the probe is right by a port. An RS typr readout would give EGT and inlet air temps at the flick of a switch, or show both on some, ffor the price of an extra sensor, but "Bling" they are not.... Link to comment Share on other sites More sharing options...
