adam1983 Posted December 2, 2015 Share Posted December 2, 2015 As per title I'm looking for a power steering pump that is in good condition. Mine is very noisy so most likely dying. Link to comment Share on other sites More sharing options...
np89 Posted December 2, 2015 Share Posted December 2, 2015 is there enough ATF in the reservoir? Link to comment Share on other sites More sharing options...
adam1983 Posted December 2, 2015 Author Share Posted December 2, 2015 Shows as full mate Link to comment Share on other sites More sharing options...
adam1983 Posted December 5, 2015 Author Share Posted December 5, 2015 Bump Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 5, 2015 Share Posted December 5, 2015 Hi matey. Have you tried doing the system bleed with fresh dexron III? My pump got a little noisy and the steering went crazy stiff. Put fresh fluid in and perfect. If you have tried that I saw a member selling a black painted one... Link to comment Share on other sites More sharing options...
wile e coyote Posted December 6, 2015 Share Posted December 6, 2015 Also the gause filter in the bottom of the reservoir gets cloged Link to comment Share on other sites More sharing options...
adam1983 Posted December 6, 2015 Author Share Posted December 6, 2015 Also the gause filter in the bottom of the reservoir gets cloged Could it be possible that the fluid in the tank is reading incorrectly then and could really be empty? How would I go about cleaning the reservoir gauze out properly? Link to comment Share on other sites More sharing options...
wile e coyote Posted December 6, 2015 Share Posted December 6, 2015 Remove the reservoir Clean with petrol but Do not poke down inside as you could damage the filter Keep cleaning till nice clean and you should see daylight The fit back on with a new o ring being careful not to pinch it Refill to COLD level engine OFF Link to comment Share on other sites More sharing options...
adam1983 Posted December 6, 2015 Author Share Posted December 6, 2015 Ok I think I will have a go at doing this and also a flush of the fluid too. Don't suppose you have the part number for the o ring so I can order before starting? Link to comment Share on other sites More sharing options...
wile e coyote Posted December 7, 2015 Share Posted December 7, 2015 Sorry I don't I have a box of different ones which I used Link to comment Share on other sites More sharing options...
adam1983 Posted December 7, 2015 Author Share Posted December 7, 2015 Sorry I don't I have a box of different ones which I used Ah ok thanks anyway. Never cleaned the reservoir before or flushed the system so want to make sure I get it right and have everything needed before I start. Did you do a flush of the system too? Link to comment Share on other sites More sharing options...
wile e coyote Posted December 8, 2015 Share Posted December 8, 2015 No just did the reservoir Link to comment Share on other sites More sharing options...
