cainhead Posted December 1, 2015 Share Posted December 1, 2015 Hello, Bit of advice needed. My jspec rears having been causing issues and decided to take them off for a refurb. I knew one was seized but got it out with some force. I was planning on replacing everything with new CW parts as pistons were a little corroded and they are 21 years old so gives me a project. Just wanted to ask some opinions. When i look into the chamber of the caliper its all very smoth and polished on the sides but at the bottom it looks and feels quite coarse. Is that normal, or has something worn away. Just dont want to spend money on new parts if I might as well look at replacing the whole thing. Also any ideas on best way to clean the chambers that the sliders go into. They were extremely hard to remove. Any comments much appreciated. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 2, 2015 Share Posted December 2, 2015 Are you talking of the slider pins, or the bores of the caliper bodies the pistons go into? The slider pin bores and be cleaned up with a snug fitting drill bit run at high speed with oil on the drill bit. The caliper body piston bores should have a good finish, but no need for anything too special, the seals are there to seal on a perfect piston finish, via the rubber seal, the bore just guides the piston. Does that help? Quote Link to comment Share on other sites More sharing options...
Scooter Posted December 2, 2015 Share Posted December 2, 2015 The course bottom bit, the flat surface you can see if looking into the hole left by the removal of the piston, is normal Quote Link to comment Share on other sites More sharing options...
cainhead Posted December 2, 2015 Author Share Posted December 2, 2015 Both your answers help so thank you. I was originally meaning the flat bit as you look into the bore where the piston was. But the help with the slider pin bore in terms of cleaning is also a great help. Thanks again Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 2, 2015 Share Posted December 2, 2015 (edited) I use either a fine grade flap wheel or a flexi hone if you feel like splashing out Or get a piece of smaller diameter steel/aluminium, cut a slot in one end and wrap fine grade emery cloth around it till it just fits in the slider pin bore, fit into an cordless drill and push it back and forth honing out the bore. Wrap the emery cloth in the opposite rotation to the drill so it doesn't unravel when you start it Use WD40 or oil to keep it lubed Edited December 2, 2015 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
cainhead Posted December 2, 2015 Author Share Posted December 2, 2015 Thanks DnK, any advice on cleaning the whole unit. Should I flush any grit/sand out with water first (drying immediately after). Any work on the piston bore recommended. Cheers Quote Link to comment Share on other sites More sharing options...
cainhead Posted December 6, 2015 Author Share Posted December 6, 2015 I'm one step away from finishing a rear calliper refurb but I'm stuck getting the slider pin dust gators to fit. They seem to have a metal fitting on the end that sits into the slider bore, however the diameter of the metal piece seems just to big to fit in. Any ideas? Cheers Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 6, 2015 Share Posted December 6, 2015 You have not removed the OLD metal collar, it's still in the bore of the slider. Look at it in a good light and get a sharp chisel under it. What you are trying to remove is the same collar that's on the new rubber gators you have. once the old collar is levered out you can tap the new one in with a suitably sized socket. Let me know if you aren't sure what I mean, but once you realise the old one iI still stuck in the slider it should all become clear Cheers. Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 6, 2015 Share Posted December 6, 2015 I'm one step away from finishing a rear calliper refurb but I'm stuck getting the slider pin dust gators to fit. They seem to have a metal fitting on the end that sits into the slider bore, however the diameter of the metal piece seems just to big to fit in. Any ideas? Cheers http://www.mkivsupra.net/vbb/content.php?57-Brake-System Page BR48 shows what Chris is on about Quote Link to comment Share on other sites More sharing options...
cainhead Posted December 6, 2015 Author Share Posted December 6, 2015 Thanks Chris that makes sense, stupidly that didn't even cross my mind as after removing the old gators there were no collars attached. I guess the bonding had just given up after 21 years. Cheers again to both of you for the assistance. Now just to fit all back on the car. Cheers Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 6, 2015 Share Posted December 6, 2015 Yes, the bonded joint fails, I don't care to think how many new gaiters get ruined when people try to tap them into a hole where the old collar still sits It's not at all obvious at first! Quote Link to comment Share on other sites More sharing options...
Annabella Posted February 23, 2016 Share Posted February 23, 2016 Yes, the bonded joint fails, I don't care to think how many new gaiters get ruined when people try to tap them into a hole where the old collar still sits It's not at all obvious at first! Cheers Chris - just saved us a whole lot of pain here Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 23, 2016 Share Posted February 23, 2016 No worries, glad it helped. Quote Link to comment Share on other sites More sharing options...
