MATT RR Posted December 1, 2015 Share Posted December 1, 2015 Hi guys, just have a question on my car, Ive noticed a sensor in the inter-cooler pipe that joins the throttle body, I've just replaced all my silicone hoses and wondered what it was doing/whats its for if anyone can help? here is a pic of the sensor in and out of the pipe: this is a pic of the pipe its in (the pipe from the intercooler to the throttle body) Thanks in advance for the help Link to comment Share on other sites More sharing options...
Dnk Posted December 1, 2015 Share Posted December 1, 2015 Inlet air temp sensor i'd imagine Link to comment Share on other sites More sharing options...
MATT RR Posted December 1, 2015 Author Share Posted December 1, 2015 Inlet air temp sensor i'd imagine thanks, is that something that's usually on most Supra's then and how important is it? Just curious as I didn't know it was there Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 1, 2015 Share Posted December 1, 2015 Looks like the std one by the plug, and someone has moved it from the plenum to the pipe. Link to comment Share on other sites More sharing options...
MATT RR Posted December 1, 2015 Author Share Posted December 1, 2015 Looks like the std one by the plug, and someone has moved it from the plenum to the pipe. Yeh the plug does look stock alright, any suggestion as to why someone would move it? Link to comment Share on other sites More sharing options...
Frank Bullitt Posted December 1, 2015 Share Posted December 1, 2015 Maybe for your ECU? Isn't it something to do with the VVTi MAF sensor? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted December 1, 2015 Share Posted December 1, 2015 VVTi has the air temp built into the MAF. The sensor you have fitted must be for an external guage or if the car has an aftermarket ecu fitted? Link to comment Share on other sites More sharing options...
MATT RR Posted December 1, 2015 Author Share Posted December 1, 2015 VVTi has the air temp built into the MAF. The sensor you have fitted must be for an external guage or if the car has an aftermarket ecu fitted? Right that makes sense, cheers guys yeh it has an HKS f-con gold ecu, there is no gauges in the car other than a defi guage for boost Link to comment Share on other sites More sharing options...
Paul Whiffin Posted December 1, 2015 Share Posted December 1, 2015 Right that makes sense, cheers guys yeh it has an HKS f-con gold ecu, there is no gauges in the car other than a defi guage for boost In that case its for the FCON yes. Link to comment Share on other sites More sharing options...
MATT RR Posted December 17, 2015 Author Share Posted December 17, 2015 Thanks Paul Link to comment Share on other sites More sharing options...
