Syvecs limp mode
FOSTA
Hi guys,
After fitting my toucan display it shows up LIMP on the screen so I hooked up the laptop to the ecu and it also shows limp mode and the DEVICES. Is flashing yellow. So I clicked on that then saw the ERRORS was also flashing yellow. So a clicked on that and it brought up this box :
The car drives the same as it did the day I purchased it so it could have always been in limp mode from the day I got it.
I'm not sure how the limp mode has been set up as the revs are not restricted and its boosting fine I only found out it was in limp mode after I connected up the toucan display as it shows me on the screen :/
Any idea how I would get it out of limp mode?
I know virtually nothing about this but Lee installed a Toucan in my car the week before last. Whilst the car is warming up it goes into limp mode. Once the engine is up to running temps limp mode switches off. Are you looking at the car whilst it is cold?
No fella, I knew the syvecs dose that but I've took this out for a 30mins drive and it never went off dude. It's just on constantly but what I don't understand is the car seems to drive fine :/
Thanks for the input guys.
Yeah I've connected all wiring as in the instructions, the only wire I did not connect is the "GRAY" wire for the cal selection. I have the s6gp with plug and play harness so I just plugged in the Ethernet into the syvecs plug and left the gray wire for now. I have the I/o expander fitted to Tim said I'll not beable to use canbus. So I just selected "syvecs" in the toucan and all seemed to work straight away :)
