Choosing the right head gasket size
Dim Sum
I am planning to rebuild the head with better parts and I was wondering if anyone could give meopinions on are head gasket thickness.
I read OEM is 1.3mm and Im planning to go with the HKS 2.0mm
I planning to use the 2.0mm to hopefully lower the compression ratio to help with the spooling.
But the questions is will it help that much?
Is it worth it, or should I use HKS 1.5mm instead?
Also I read somewhere it will likely cause gasket failure (or will that only apply to cheap head gasket)?
How does that work? The lower the compression, the soggier the engine is off-boost so I'd imagine it'll make spool worse, not better?
I read that "Thicker than the factory head gasket, which will slightly reduce compression allowing for even higher boost" So I am assuming that low compression rate will be better for a turbo car
Edited by Dim Sum (see edit history)
Get your engine builder to recommend a suitable CR and squish for the fuel you will use. DO NOT just assume things, get him to measure chamber volume on each cylinder, and any piston dish or valve cut out volume (the piston maker should state this for unmodified pistons). Allow for piston protrusion, gasket volume, plug volume, and do the maths. Anything else is guesswork. He should have all the measuring gear.
If you are building the engine yourself you can buy a large burette, a depth gauge, and make a perspex plate to seal the head chambers. There are plenty of books and web articles on working out compression ratios. Time consuming but not hard if you work carefully and take proper notes.
Actually, glad I found that Yank, I can pull holes in him now ;) Look at the bottom (head chamber) end of the plug thread in the head chamber he's working on. See how there's no radius on it, just sharp edges or flaps of ally athe bottom of the threads? That is a text book classic example of a bad head prep, it WILL cause det or pre-combustion and should be hand finished to a smooth radius. Under duress that sharp edge will glow red hot.
