OD off light flashing but no fault codes.
supradanturbo
  • 3 weeks later...
Hi just seen a message u sent to a member who was saying his od light was flashing with no fault codes.
Im just messaging as my supra has been cutting out and when ignition turnt i get no mil light but the od flashes on and off.
Saw ur message so seeing if u know why that is as you seemed to know something.
Cars a 95 tt jspec manual
Gareth
Guest Big red johnson
Both my overdrive light and my traction control lights flash alternately , pulled the trac fuse in the end, ecu gave no error codes but the car would go a certain distance then go into what felt like a limp mode, not change out of 1st then go back to normal again, hasn't done it since pulling the fuse.
