Andrew K Posted November 21, 2015 Share Posted November 21, 2015 (edited) Engine type - Single Turbo, 2JZ-GTE Engine Spec - SRD Stage 2 head, SRD Stage 2 cams 269 profile 9.6mm lift, Stock bottom end Fully balanced & line honed block Turbo - Precision T6765 .68ar Intercooler - Chris Wilson SMIC Fuel Used - Shell V-Power Nitro+ Injectors - Sard 800cc drop in's Fuel Pump - Single Walbro 485 Exhaust - 3" HKS Silent Hi-Power, 3" mid pipe & Down pipe Transmission - V161 & Spec Stage 1 clutch Ecu - Syvecs S6 Mapped By - SRD & Lee at Devil Developments Dyno Used - Devil Developments (Dyno Dynamics) Power Figure - 617.7hp at the Flywheel, 524hp at the wheels Torque Figure - 510 ft/lb Boost Pressure - 1.6 Bar http://www.mkivsupra.net/vbb/attachment.php?attachmentid=206897&stc=1&d=1448131395 Edited January 16, 2017 by Andrew K (see edit history) Quote Link to comment Share on other sites More sharing options...
Luxluc Posted November 21, 2015 Share Posted November 21, 2015 Good result Andrew Quote Link to comment Share on other sites More sharing options...
mellonman Posted November 21, 2015 Share Posted November 21, 2015 Nice mate . I have that exact turbo on mine with stock cams and the torque drops off massively , but with them cams your keeping it nice and flat great end result Quote Link to comment Share on other sites More sharing options...
Andrew K Posted November 22, 2015 Author Share Posted November 22, 2015 Good result Andrew Thanks Luc I'm still chuffed to bits with the result I got as more than I was expecting Quote Link to comment Share on other sites More sharing options...
Andrew K Posted November 22, 2015 Author Share Posted November 22, 2015 Nice mate . I have that exact turbo on mine with stock cams and the torque drops off massively , but with them cams your keeping it nice and flat great end result Thanks mate, I've had good comments regarding the power / torque figures so hoping that's because of the cams / head work that had been done previously. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 25, 2015 Share Posted November 25, 2015 Great results, great area under the curve. My spec is just a little lower than yours with stoxk vvti cams, so it's nice to get an idea of what mine will be like Quote Link to comment Share on other sites More sharing options...
