strange clicking noise
Guest Wakeemkls
Guest Wakeemkls
Hi all, i have had my supra for about 3 months now, it's a beautiful car and i've had very few issues until now.
The car is a 93 N/A supra.
The last time i drove it properly home it drove fine, no noises at all. The next morning i went to drive it and there was a clicking sound. Here is what i have gather about the noise:
1) it sounds like it's something to do with wheels due to the fact that at slow speeds the clicks are far apart, whereas when speeding up the clicks become closer together to the point where it is almost just one solid unbroken clicking noise.
2) the sound is metallic. at first i thought it was the exhaust hitting the road or something similar, because my last car had an issue where the exhaust was hitting the road and this sounds almost identical. (it's not the exhaust i checked and it is hanging where it should be.)
3)i've jacked the car up and looking for anything that could be making the noise and with my low level of experience and knowledge i couldn't see anything obvious that would cause the noice
Thanks for your time, i hope that someone is able to help me or give me an easy fix asap so i can back onto the road ! :)
Guest Wakeemkls
also, i've read up a bit of people saying that this could be a wheel bareing going out, but i don't think it is this as their descriptions do not match mine, also the noise doesn't immediately go away when the brakes are applied, it just slows down the frequency of the click.
- - - Updated - - -
When was the last time you checked the wheel nuts?
This, sounds stupid but I had the same thing many years ago. Had a friend of mine drive it slowly next to me found out where it was coming from took the centre cap off and a wheel nut was loose in there rattling around. :blink:
Same I had a clicking noise and it was loose wheel nuts also.
Jack each wheel off the ground and spin them, then listen
If the noise speeds up and slows down with the speed of the car
it can only be something linked to a part that rotates and changes
speed at the same rate the vehicle changes speed
loose wheel nuts
handbrake shoes
brake disc pads
brake disc back plates
wheel bearings
cv joints
drive shafts
differential
prop shaft
gearbox and clutch
Guest Wakeemkls
Hey guys this morning i have spent all my time trying to fix this. I have checked the rear brake shoes, the wheels nuts and i'm stil having the exact same issues as before :(
Have you jacked each corner up to see if the problem is actually at one of the wheels ?
Guest Wakeemkls
Hey guys just thought i would write a quick response to let you guys know i found the issue, after quite the detailed inspection i found that the cv joint was missing 4 of the 6 bolts and thus making the noise. ordering the new bolts tomorrow!
So if you hear a metallic clicking sound when you're driving and it only goes away when you slow the car almost to a stop, check your cv joints!
Thanks again guys and special mention for Dnk for the big list of things that help me find the issue ! :)
Always happy to help :thumbs:
It would be worth spending an hour on a ramp and do a bolt check, basically go round nipping up
every nut & bolt you can see on the underside of the car
Could also be worth checking the nut on the drive shaft in the hub in case that's also not been done up
properly, it should be around 290 nm
