jackso11 Posted November 20, 2015 Share Posted November 20, 2015 So my engine is finally rebuilt and will be going back in shortly (After a year off the road!) and I have only just now looked at my auto box that is going back in and though maybe I should change the torque converter? I don't really know much about torque converters, how often should they be changed? I presume as a certain age they are likely to start slipping? While its off I should probably change it right? Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted November 20, 2015 Share Posted November 20, 2015 (edited) I'd recommend changing the Autobox oil and filter, you have two options A full gearbox flush which will require I believe 8 litres of Automatic transmission fluid (ATF). Or you could drain the auto fluid from the gearbox pan, replace the gearbox filter and top up with fresh ATF. Which I think is around 5 litres. Edited November 20, 2015 by Chris Bailey (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted November 20, 2015 Share Posted November 20, 2015 As long as no muck has got in it, it'll be fine. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted November 20, 2015 Author Share Posted November 20, 2015 Yes I will flush and re-oil, although I know some people say its best to just drain and top up instead of a full flush and change...any opinions on that? Its whether or not I should put a new torque converter on that I have no idea about. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted November 20, 2015 Author Share Posted November 20, 2015 As long as no muck has got in it, it'll be fine. Thanks, should be ok then. Just in case, as it has been stood for a year attached to my old engine (in the corner of the workshop) while we rebuilt the new one (spare time only...hence taking a year!) is there a way to clean them? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 21, 2015 Share Posted November 21, 2015 Just sit it on a bucket, neck down and it will drain almost all its contents out. But don't then store it somewhere damp. TC's either work or they don't, they are simple internally and if it worked fine before I'd just refit it. You do know it must be fitted loose inside the bellhousing of the gearbox, and not bolted to the flex plate when fitting engine or transmission? It also needs gently pushing in and turning until the notches on the end of the neck engage the dogs of the oil pump just inside the front of the transmission. it will then go in another inch or so. failing to do this will probably result in a knackered transmission oil pump. You don't NEED to fill it with oil before refitting, although some people put some fluid in. I don't as it gets messy. There will be enough oil in a used converter to lube things until the pump recharges it. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted December 1, 2015 Author Share Posted December 1, 2015 Thanks Chris. It won't be me fitting it and hopefully the guys who will be fitting it already know all of that but I will pass on your words of wisdom to make sure Quote Link to comment Share on other sites More sharing options...
